Customsuspention.com
Discussion in 'Suspension' started by Buck717, Mar 3, 2014.
  1. Mar 3, 2014 at 4:57 PM
    Buck717
    Buck717 [OP] Well-Known Member
    Middletown, P.A.
    2011 TRD off road DC
    BDS 6" lift 33x12.5 Mickey mtz 18" XD monster rims White knuckle rock sliders Boztec rear diff plate Rear diff vent mod Compustar alarm/remote start with two way remote.
    I tried searching, didn't find anything. I'm just wondering if anybody has tried their springs. I want a 6" spring and the price is good but I can't find any reviews.
  2. Mar 3, 2014 at 5:02 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Perhaps you meant CustomsuspenSion.com?
    Have literally never heard of them...
    If you're looking for 6" lift in the rear...most likely you're going to need blocks. I'm currently running All-Pro Expedition springs and those are running 4"-5" unloaded and are STIFF!
  3. Mar 3, 2014 at 5:19 PM
    Buck717
    Middletown, P.A.
    I'm running the BDS 6" lift. Which gives you 4" blocks in the rear which levels the truck out. All good except when I'm carrying my gear then I'm sagging in the back. I'd really like to get away from blocks all together with a 6" spring. This is the only place that has them that I can find but nobody seems to have ever heard of them. It's a Canadian company.
  4. Mar 3, 2014 at 5:27 PM
    VolcomTacoma
    Jeff
    NorCal
    I can't say I've ever heard of them, I wouldn't personally run a suspension component from a company no ones heard of, so unless someone chimes in, ehhhhhh. Not to say they might be legit...but then again you might get a super arched spring that'll give you 6" of lift for about a month and then sag like crazy.
    I would say you could get away with All Pro Expos and a 1" block and probably be level. Those expo's can handle some serious weight. You'll definitely get at least 4" of lift in the rear, if not almost 5"....I would say try those and if you want a little more lift, a little block won't hurt as much as a giant 4" block lol
  5. Mar 3, 2014 at 5:32 PM
    Buck717
    Middletown, P.A.
    True. That might be the way to go if nobody chimes in. Or just add a leaf, I have a custom traction bar already so wrap isn't an issue, I'm just not a fan of blocks lol
  6. Mar 3, 2014 at 5:41 PM
    VolcomTacoma
    Jeff
    NorCal
    Add A leaf is merely a bandaid for a sagging leaf pack. And you're not gonna pull 4" with an add a leaf lol.
  7. Mar 3, 2014 at 5:44 PM
    Buck717
    Middletown, P.A.
    I meant on top of the 4" blocks I have now, so it doesn't sag when loaded.
  8. Mar 3, 2014 at 5:48 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
  9. Mar 3, 2014 at 5:50 PM
    Buck717
    Middletown, P.A.
    Yeah that's what I'm looking at.
  10. Mar 3, 2014 at 5:51 PM
    VolcomTacoma
    Jeff
    NorCal
    If you go for the AP expo pack you won't need the 4" blocks.
    That custom pack thing looks like its gonna be SUPER stiff. That thing looks super arched and has ALOT of leafs...oh my
  11. Mar 3, 2014 at 6:02 PM
    Buck717
    Middletown, P.A.
    Yeah with the AP if any block would be needed it'd only be a 1". Still would rather avoid blocks.
  12. Mar 3, 2014 at 6:05 PM
    VolcomTacoma
    Jeff
    NorCal
    I would just get the AP expo pack and see how you like it. You'll maintain at least 4" with several hundred lbs in the back. I think i was pulling a good 5" unloaded as soon as I installed with no weight in the bed.
  13. Apr 25, 2014 at 2:03 PM
    Buck717
    Middletown, P.A.
    Well I ordered the 6" ones from custom suspension. I'll update here and there and let you guys know what I think. Now I just need to figure out what shims to get. 4° or 6°?
  14. Apr 30, 2014 at 6:34 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    ^For future reference, you can also get 6" lift springs from Alcan. They make springs to-order at any spec you want.
    That being said, update this thread with your impressions once your new springs are in.
  15. Apr 30, 2014 at 11:43 AM
    Buck717
    Middletown, P.A.
    Will do
  16. Apr 30, 2014 at 11:50 AM
    Buck717
    Middletown, P.A.
    Do you happen to know what degree shim he's running?
    I ordered 4° and 6°, figure I can return whichever I don't need.
  17. Apr 30, 2014 at 12:49 PM
    Buck717
    Middletown, P.A.
    Oh ok thanks
  18. Apr 30, 2014 at 12:50 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    could run expos with new shackles?
  19. Apr 30, 2014 at 12:54 PM
    Buck717
    Middletown, P.A.
    Could I guess, I just wanted to try this company and see if they're any good. Hope so, or I'll again be looking for springs. I would think it's not hard to make decent springs, not like it's new technology. I'm hoping they're not overly stiff, don't start to sag early, and can take some abuse for several years.
  20. May 20, 2014 at 3:47 PM
    Buck717
    Middletown, P.A.
    The springs are made to order and there were a few ahead of mine, so they just shipped today. Coming from Washington state to PA, it'll probably be a week or so until I get them.
