Cut and weld-it-yourself bumper blueprints
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96BlueTacos, Sep 28, 2020.
  1. Oct 3, 2020 at 2:18 PM
    #41
    96BlueTacos
    96BlueTacos [OP] トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Hahaha nice
  2. Oct 3, 2020 at 5:47 PM
    #42
    Kwe1982
    Kwe1982 Well-Known Member
    Wisconsin
    Gone - Just a couple Tundras and a Sequoia
    Got the steel cut and mocked up, welding tomorrow.
    488253CD-79AF-49C5-B476-ACC0174CA210.jpg 65D45E12-E168-4237-B484-2998A353B63C.jpg B494FD65-E4BB-4837-9900-FC4B55213A0C.jpg
  3. Oct 4, 2020 at 4:14 PM
    #43
    Gnarlyshredder
    Gnarlyshredder Well-Known Member
    Jacob
    SoCal
    1999 Prerunner
    Suspension: Bilstein front/rear 5100's (set at 3" lift) Eibach front coil springs 620lb Toytec 2" add-a-leafs Wheels/Tires: Pro Comp 7069 Series Alloy Wheels 285/75/15r General Grabber AT2s
    @Kwe1982 I'm honored you're using my design! Looks great so far, I'm excited to see how it turns out!!
    Kwe1982 likes this.
  4. Oct 4, 2020 at 11:12 PM
    #44
    Running Board Man
    Running Board Man Well-Known Member
  5. Oct 5, 2020 at 5:37 AM
    #45
    96BlueTacos
    Mikey
  6. Oct 5, 2020 at 2:11 PM
    #46
    Kwe1982
    Wisconsin
    Welded and painted, thanks to my brother.
    06A8C919-1458-4E8A-8F11-DA2CF83EC687.jpg 3C97B096-E096-4499-9216-FE718CDAC806.jpg 9715FEEC-F9F4-4F90-B418-1BFEB691F56A.jpg CA109082-7D4F-487E-A25D-3CC8D023B79C.jpg
    Dalandser and 96BlueTacos[OP] like this.
  7. Oct 5, 2020 at 2:45 PM
    #47
    96BlueTacos
    Mikey
    Looks good! How thick is that main members wall?
  8. Oct 5, 2020 at 3:05 PM
    #48
    Kwe1982
    Wisconsin
    I used 2x6x3/16”, others have used 1/4”
  9. Oct 5, 2020 at 3:28 PM
    #49
    Gnarlyshredder
    Jacob
    SoCal
    1999 Prerunner
    @Kwe1982 I'm jealous of those beads your brother laid down! It turned out nice and clean
    Kwe1982 likes this.
  10. Oct 5, 2020 at 7:35 PM
    #50
    Running Board Man
    3/16 is plenty if you look at the frame it bolts to
  11. Oct 5, 2020 at 7:43 PM
    #51
    96BlueTacos
    Mikey
    That true!
    But since I’ll be getting scrap from the welders across the way, I’ll be kind of limited to whatever they have. I’m noob AF with metal and steel fab so I was just trying to get an idea of what thickness I should ask them for. That’s why I’m going to tackle this bumper. I need to get the practice of bead laying in. All I’ve been doing is welding random pieces of metal together.
  12. Oct 5, 2020 at 7:44 PM
    #52
    Running Board Man
    3/16 is ~1.75x the thickness of the frame
  13. Oct 5, 2020 at 8:15 PM
    #53
    96BlueTacos
    Mikey
    what does that make the frame like 7/64ths?
  14. Oct 5, 2020 at 8:25 PM
    #54
    96BlueTacos
    Mikey
    what method did you use to cut out your holes for the hitch receiver and the hook loops, or whatever those are called? just carefully with a cutoff wheel? I have metal blades for my jigsaw, but ive never used the jig on metal before. I was just gonna use my skills with a cutoff wheel and a hack saw:sawzall:
  15. Oct 5, 2020 at 8:37 PM
    #55
    Running Board Man
    1/8
  16. Oct 5, 2020 at 9:16 PM
    #56
    96BlueTacos
    Mikey
    1/8 is 0.125 x 1.75=0.2187
    0.2187=7/32 which is 1/32 less than 1/4
    7/64 is 0.1093 x 1.75=0.1914
    0.1914 is right between 3/16 and 13/64
    so if the frame is 1/8=0.125
    0.125 x 1.5 = 0.1875 or 3/16ths
    :thumbsup:
  17. Oct 5, 2020 at 9:23 PM
    #57
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Frame is double layer of tin foil.
  18. Oct 5, 2020 at 9:28 PM
    #58
    96BlueTacos
    Mikey
    :rofl::rofl::rofl: that just made me actually laugh out loud.
  19. Oct 5, 2020 at 9:53 PM
    #59
    Running Board Man
    ~ means about
  20. Oct 5, 2020 at 10:28 PM
    #60
    Gnarlyshredder
    Jacob
    SoCal
    1999 Prerunner
    I had someone plasma cut the holes on mine... it could be a heck of a lot of work to get clean cuts with a cutoff wheel and a hack saw. Might be worth it to check out a weld shop for that.
