Cut and weld lower control arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Muddinfun, May 21, 2017.
  1. May 21, 2017 at 10:06 AM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    the issue here is you're not trying to weld a frame. the panels of frames are what provide the support and flexability more than the welds themselves. you cutting off a suspension component and trying to reweld it together solely puts the strain on the weld. and pure weld isnt as strong as a solid piece of metal unless you can get a better consistency and thickness all the way around which I doubt you can do on the inside potion of the weld.
    but before we discuss anything further, what truck or lower control arm are you referring to?
    MotoEd likes this.
  2. May 21, 2017 at 10:06 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Build a whole new lower arm if your going to go through the trouble of doing it correctly, jig the stock arm and adjust from there, it doesn't take much movement to make a HUGE change in the geometry.
    By just moving the lower mount yes it will achieve what your trying to do till the suspension cycles and the antidote that's built into the upper arm mount will suck the tire back towards the firewall.
    Also, just moving the lower will introduce more bumpsteer into the system. You also will have to put a degree of tilt in the pivot too to get the joint to cycle correctly and not bind through turning and cycling...
    Just some things to think about
  3. May 21, 2017 at 10:09 AM
    Basikbiker
    Trav
    MotoEd likes this.
  4. May 21, 2017 at 10:09 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    Simple jig like this would work.
  5. May 21, 2017 at 10:10 AM
    jakebray
    jakebray Well-Known Member
    jake
    SoCal
    13 PreRunner
    Locked DCLB with Kings and crap
    A weld is stronger than the metal
    MotoEd likes this.
  6. May 21, 2017 at 10:16 AM
    jakebray
    jake
    SoCal
    13 PreRunner
    In all honesty it sounds like an awesome idea but I would probably recommend just buying an oem replacement lower from total chaos or whoever else has it, this project will take some real work to get everything to line up correctly and on top of that you run the risk of failure which can be serious. Plus after materials amd time you may find it might be an option to just purchase the lowers. This is just what I think about it. If you do go for it post pics I want to see :D
    MotoEd likes this.
  7. May 21, 2017 at 10:23 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    https://www.youtube.com/watch?v=Y5gpoZzwcKY
  8. May 21, 2017 at 10:29 AM
    CodeSeven
    Serge.
    Coachella Valley
    So you're saying if we can hook up a tig/mig welding tip to a 3D printer, we can make anything stronger than hot it's currently being manufacturered?
  9. May 21, 2017 at 10:48 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You gots that bass ackwards there. You thinking UCA, not LCA?
  10. May 21, 2017 at 10:57 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yeah you're right! haha my bad.
    landphil[QUOTED] likes this.
  11. May 21, 2017 at 12:06 PM
    Muddinfun
    Muddinfun [OP] Well-Known Member
    Thanks for all the comments, advice, encouragemant, and criticism. If you look at the stock lower control arm, you will see that it's made of at least 6 pieces, all welded together. As I mentioned, I have complete confidence in my welding guy's abilties to make it much stronger than it needs to be. My intention was never to get 10 degrees of caster and 2" of tire clearance. Everyone who has posted their alignment experience here, with a lifted/ leveled Tacoma, has had to have the alignment guy max out the caster while still maintaining the camber close to 0. The end result is caster that is "OK", but not ideal. My intention here is to get the alignment where it needs to be and not have to settle for "best we could do". So, we're not talking about altering the geometry drastically. Just a minor little change to make it drive the best you can on the street.
  12. May 21, 2017 at 12:07 PM
    anthony250f
    Anthony
    San Diego, CA
    So....what size tires??
    And yes it sucks getting the caster/camber perfect!
  13. May 21, 2017 at 12:33 PM
    Muddinfun
    At this point, just 265/75-16 with 5100s set at 1.75 and a lean spacer. When I tear into the rusty bolt situation, to install the 5100s, and align, I plan to just buy new Moog control arms, and thought about modifying them before install.
  14. May 21, 2017 at 12:34 PM
    anthony250f
    Anthony
    San Diego, CA
    Is it really needed for 265? I'm running 315 and it's not even that big of an issue.
    Tacosail, MotoEd and Basikbiker like this.
  15. May 21, 2017 at 12:51 PM
    #35
    Justinlhc
    Justinlhc Not looking for a relationship
    I was assuming you were planning on running at least a 35" tire to be considering cutting and relocating the LCA. I don't think you'll have any issues clearing ~31.5's with a 1.75" lift. :confused:
  16. May 21, 2017 at 12:56 PM
    #36
    Muddinfun
    I'm not wanting to modify the control arms for tire clearance. That's just a byproduct. I'm wanting to be able to get the alignment the best it can be for a truck that's 99% daily driver.
    Toy4me likes this.
  17. May 21, 2017 at 1:13 PM
    #37
    Justinlhc
    Have you considered just buying new upper control arms?
    What caster setting are you aiming for? At only 1.75" of lift I don't see why you can't get your caster in the 2°+ range?
  18. May 21, 2017 at 1:18 PM
    #38
    Muddinfun
    Like I mentioned, aftermarket upper control arms sacrifice tire clearance in order to increase caster.
    I would like to get 4 degrees of caster.
  19. May 21, 2017 at 3:05 PM
    #39
    Justinlhc
    Yes, but like you mentioned, you're only running a 31.5" tire. o_O
    Even if you did rub somewhere a tiny bit I'm thinking it would be easier to just shave a little plastic or metal than refabricate a lower control arm?
    bullaculla and EatSleepTacos like this.
  20. May 21, 2017 at 5:16 PM
    #40
    Basikbiker
    Trav
    Yea unless your running 35's or over there is no point to do what your thinkin
    bullaculla and MotoEd like this.
