Cut and weld lower control arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Muddinfun, May 21, 2017.
  1. May 21, 2017 at 5:32 PM
    #41
    scleaf
    scleaf Well-Known Member
    Torrance, California. USA
    2013 Silver Tacoma TRD 4x4
    SaBellCo's Tailgate Lock :), Cable mod
    Nice tooling and setup. looks super strong.
  2. May 21, 2017 at 5:37 PM
    #42
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I was running total chaos stock length upper and lower control arms. Caster was over 4 degrees, and I cleared my 285/75/16 MTR/K tires with no cab mount chop.
    I was running over 3 degrees just with the TC UCA.
    MotoEd likes this.
  3. May 21, 2017 at 5:44 PM
    #43
    scleaf
    Just do it, worse thing is you will have to buy an aftermarket replacement. You will never know unless you try... I am sure there are plenty of stock replacements available in this forum.
    MotoEd likes this.
  4. May 21, 2017 at 6:25 PM
    #44
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Ditto just do it
    MotoEd likes this.
  5. May 21, 2017 at 7:09 PM
    #45
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    With the lift you have you should be able to get 4 degrees of caster if you just get SPC ucas. Have your alignment guy max out your factory cams to get maximum caster and adjust camber at the UCA. Add caster at the UCA by rotating the ball joint until you get to your desired numbers. Readjust the lower cams if needed to even out both sides.
    By doing this you should have lots of room behind the tire and away from the cab mount or fender flares.
  6. May 22, 2017 at 12:30 PM
    #46
    jakebray
    jakebray Well-Known Member
    jake
    SoCal
    13 PreRunner
    Locked DCLB with Kings and crap
    No I'm saying that the material laid down from a weld is stronger than the metal it is fusing together
    MotoEd likes this.
  7. May 22, 2017 at 12:40 PM
    #47
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    I'm pretty sure the control arms are forged and therefore could be welded fairly easily. However you would need to send them out to be stress relieved and have the heat treat re-done to factory specs. Not worth the effort when you can by aftermarket stock length arms.
    Normal weld filler is at least 70,000 psi tensile strength. Much stronger than the material being welded. This creates problems though because it causes stress and can lead to cracks in the base materials.
    MotoEd likes this.
  8. May 22, 2017 at 12:45 PM
    #48
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you really need clearance get SPC arms.
    Take your stock LCA and adjust them so the lower control arms outer point is the furthest forward you can possibly be (Front LCA bolt slid all the way to centerline, rear slid all the way out from centerline) then use the SPC arms to get your zero to sligntly negative camber back.
    FYI the LCA has way more effect on wheel placement within the wheel well than the UCA as the center of the hub is MUCH closer to the lower ball joint than the top.
    But like stated unless you are like @snowsk8air2 on brand new 35's, you arent gonna need to modify the LCA.
  9. May 22, 2017 at 12:48 PM
    #49
    Muddinfun
    Muddinfun [OP] Well-Known Member
    There is no way Toyota is heat treating the control arms, or the frame, or the rear axle housing, or the aluminum front bumper reinforcement. They probably build a prototype, jump it 12" and if it holds up, they call it good.
  10. May 22, 2017 at 12:49 PM
    #50
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  11. May 22, 2017 at 12:57 PM
    #51
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Frame no, but the forged parts have to be treated to get a consistent strength. When they do the forging the metal would be so hard that it would easily crack when stressed. It has to be annealed and tempered to an appropriate hardness for the application.
  12. May 22, 2017 at 4:23 PM
    #52
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    I tool around on this site a lot and have never seen anyone do this, and to be quite honest, just to get a small bump in caster its borderline insane.
    My personal recommendation would be if you are dead set on increasing caster via the LCA I would recommend calling anyone who manufacturers aftermarket LCAs and inquire if they add caster by default with their design.
    Another idea......I believe when people lift and get their trucks aligned most people aren't able to max out their caster cam without introducing excessive positive camber(my personal experience), a heimed UCA will allow you to COMPLETELY max out caster on the LCA and set camber to zero via the heimed UCA. Just to warn you though, if you max out your caster cam the bushings(if using a aftermarket LCA my not be completely covered by the mounting tabs and look weird(possibly be detrimental, it doesn't look supported correctly), I currently have this problem and intend on pulling it back in an make adjustments to my heimed UCA to compensate.
    You seem like you are already set in what you want to do and are just looking for validation despite everyone giving you advice to the contrary. Good luck with your endeavor.
  13. May 22, 2017 at 5:28 PM
    #53
    Muddinfun
    As I mentioned, I do appreciate all the opinions. Obviously nobody has done it before. I'm not dead set on doing it, but at this point am considering it. As far as "the alignment guy", that's me. I do alignments on very high dollar street rods, and few restored classic muscle cars. I don't do run of the mill family vehicles or punk kid cars. I am very picky about getting the alignment perfect. It bugs the hell out of me when I see the TV shows with high dollar street rod builds (Boyd Coddington, Chip Foose, The monkey guys, etc), going down a straight road, and the steering wheel is crooked. Obviously there's much more to alignment than getting the steering wheel straight, but if they can't even get that right, how screwed up is the rest of the car? I checked out a Boyd Coddington built car, and I told the owner of it that I wouldn't work on it, and to come get it. What a screwed up mess! The engine oil pan was sitting on the crossmember! Anyway, later this week, I am going to get the Tacoma on the rack and see just what happens to the alignment when you raise it 2" or 2 1/2". Then I will decide from there which way I will go with it. As mentioned above, I'm sure the camber goes negative and limits what you can do with the caster. I know I could spend $500 on aftermarket UCAs and dial it in, but it hardly seems worth it for a 2" lift on a 99% street driven truck.
  14. May 22, 2017 at 5:37 PM
    #54
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    "but it hardly seems worth it for a 2" lift on a 99% street driven truck"
    I would say the same statement about what you're planning on doing...are you going to cycle the suspension? Are you going to build a jig for the lower arm?
    EatSleepTacos and steveo27 like this.
  15. May 22, 2017 at 5:42 PM
    #55
    Muddinfun
    Yes, just a basic jig so the ball joint location and angle are properly relocated. Maybe I'm nuts, but it's worth considering.
  16. May 22, 2017 at 5:56 PM
    #56
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    you wanna dial in my alignment for me? :D
    Shops around here suck with their responses like "that's not Toyota specs" (duh) or "we got it close, you won't notice" (oh I'll notice).
    beertimecontinuum likes this.
  17. May 22, 2017 at 5:58 PM
    #57
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Here's what I do, keep it on the down low though. I'm subbed for cut LCAs :cheers:
  18. May 22, 2017 at 8:39 PM
    #58
    Justinlhc
    Justinlhc Not looking for a relationship
    I'd be VERY interested to see your report on messing with your alignment on the Tacoma. You're going to end up with positive camber that you can't dial down though, not negative(unless you reduce caster to nothing).
    I've got the SPC upper arms so I've tweeked the hell out of my alignment to be exactly where I want it, although I'm sure the toe isn't as perfect as a machine can get it.
  19. Nov 30, 2019 at 8:32 PM
    #59
    JanBoothius
    JanBoothius Well-Known Member
    Jan (Pronounced Yon)
    Upstate New York
    2015 TRD OR DCSB 6 speed
    Heavy stuff big tires drives like hell
  20. Nov 30, 2019 at 8:43 PM
    #60
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Just don't change the permanent structure of the metal and it's fine to weld on anything. Haha. Yea.
    Seriously, anything can have a proper procedure made for the material/thickness/rate/current. It's what a weld engineer does. Guys who do it by feel are like people who can play the piano by ear instead of by sheets. Kinda...almost....
    Anyway. As long as the welder is competent, I'd trust it fully. If you've driven within 5 miles of a refinery, you're trusting your life to a weld.
    I say 5 miles because we were just told to evacuate 4 miles around a plant for Thanksgiving. Yea, that's us. Maybe welding isn't a good idea after all.
