Cut fenders not sealed
Discussion in 'Long Travel Suspension' started by mxxdude, Jan 19, 2013.
  1. Jan 19, 2013 at 10:40 AM
    mxxdude
    mxxdude [OP] Well-Known Member
    Brandon
    Tucson AZ
    06 4x4 TRD
    I bought my truck with the High clearence bumper on it. The shop did a good Job cutting then straight but they didn't seal of the cut so the paint is starting to chip a little . Should I take off the bumper? Or can I just use a little touch up paint without taking it off? Thanks
  2. Jan 19, 2013 at 10:43 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  3. Jan 21, 2013 at 6:22 PM
    mxxdude
    Brandon
    Tucson AZ
    06 4x4 TRD
    i live in az so no rust
  4. Jan 22, 2013 at 9:58 AM
    XXXX
    sKiP
    05 Prius
    That looks to be bubbled from the heat of whatever they used to cut it and not rust. I have cut into quite a few Toyota panels and with my experience that's heat bubbles.
    IMO that shop sucks and I would never go back. Anyone leaving a raw edge like that is a assclown :D
    Now you need to sand down both sides until no rust is present (tape off t5rhe good paint first to protect it). Then hit it up with a self etching primer and touch up paint. I would then throw some caulk filled molding over it.
    Good luck man.
  5. Jan 23, 2013 at 2:24 PM
    mxxdude
    Brandon
    Tucson AZ
    06 4x4 TRD
    Gracias senor thats the plan
