Cut or Bend...Removing UCA Bolt
Discussion in 'Suspension' started by AllMountainToy, Jan 15, 2013.
  1. Jan 15, 2013 at 12:18 PM
    AllMountainToy
    AllMountainToy [OP] Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    I have read the two different and both fantastic write ups on the replacement of the UCAs and the UCA bolt by NickLam and Silver06TRD.
    I know some have cut the bolt and purchased a new one from toyota and others have bent their wheel well just enough to get the bolt through. I will be replacing my UCAs this weekend.
    Want to get an idea from people that have done one or the other.
    Easier to:
    A. CUT?
    B. BEND?
    dpele likes this.
  2. Jan 15, 2013 at 12:20 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    if im understanding you correctly, i bent.
  3. Jan 15, 2013 at 12:28 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Bend. I've seen cut tried and think a little paint damage is totally worth it.
  4. Jan 15, 2013 at 12:31 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Cut was rather simple and fast.....
    Of course you need to add the time to go to the dealer to get the new bolts.
  5. Jan 15, 2013 at 12:35 PM
    superwhite
    superwhite Well-Known Member
    sean
    Western NC
    07 double cab 4x4
    Dana 60 rear Chevy 63's shackle flip mid travel gears lockers and 38's in progress
    Bend. It's really not that bad. I used a hole saw on my radiator support and slid the bolt straight out the front.
  6. Jan 15, 2013 at 1:16 PM
    AllMountainToy
    Northern California
    Did you need to cut or drill anything or really simply just bend?
    Thanks
  7. Jan 15, 2013 at 2:26 PM
    97yota4wd
    Eric
    Mesa, AZ
    my trucks a first gen and i have most stuff ripped off the front end so im not sure for your case.
    but i just pulled and kicked and it was easy for me at least.
  8. Jan 15, 2013 at 3:41 PM
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    Bend, it was easy. New bolts $12 each.
  9. Jan 15, 2013 at 3:46 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I have done both actually. My experience- cutting was easier and quicker, used a sawzall with a nice metal blade. If you cut on the passanger side it literally takes 2 minutes to remove the UCA and have the new bolt ready to go in. On the drivers side you will still have to move stuff either way if you cut or not. I think i paid $12 a bolt, was it worth it? To me yes, i did the install without any help and basic tools so wherever i could make it easier for myself it was worth it.
  10. Jan 15, 2013 at 3:59 PM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    I bent and put the bolts back in the same way, wasn't that hard but did take a couple of hours.
  11. Jan 15, 2013 at 4:11 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    I bent my wheel wells a little to get mine out and i put them back in the same way too the first time. To make the install easier ground down the washer side to one of the 6 sides of the bolt head. The second i had to remove them the flat side I had made made it way easier to remove. Even my first time removing them I got them out really quickly, just unbolt the bracket that holds the brake line if you put them in from the back instead of the front.
    I reinstalled mine the factory way to help cut down on rust buildup on the threads from road salt. Then coated them with black farm equipment paint.
  12. Jan 15, 2013 at 7:04 PM
    darktaco
    darktaco Active Member
    N.E. , Pa...U.S.A.
    08/Sport
    scangauge/c.b.-cobra 29/ BO chrome badges/Demello bolt on sliders/rcbs 4x4 led mod/rear tsb / relocated trailer plug to plate light hole/ Toytec U.L.K./L.R. UCA's/AFE-pro-dry air filter/LEDS -plate,dome,map lites /rear diff breather/ImMrYo's mirror lift/redline hood lift,
    I used a crow bar.
    Tap it out until it stops just beyond the pinch weld you bent with the
    big channel lock pliers.
    I used a 4 inch bolt as a pusher.
    Then lift it a bit to put a washer under the bolt head collar .Then keep tapping out.
    To reinstall reverse procedure.
    I did remove the battery and tray .YOU WILL LOOSE YOUR RADIO PRESETS !
    Watch for the lines in the way .Go slow.
    Key-Rei likes this.
  13. Jan 15, 2013 at 7:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    X2
    I bent , but not because I'm too cheap to spend $24 on new bolts but because it wasn't to bad to do
  14. Jan 15, 2013 at 7:11 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    X3
  15. Jan 15, 2013 at 7:13 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  16. Jan 15, 2013 at 7:50 PM
    AllMountainToy
    Northern California
    Thanks all I am so tempted to cut with sawsall and new blade for speed sake but leaning toward the bend.
    appreciate the feedback.
  17. Jan 15, 2013 at 9:07 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Bend bend bend!
    I cut one and still had trouble getting it out. Then on the other side I bent the metal with some pliers and had the bolt out in 2 mins.
  18. Jan 15, 2013 at 9:09 PM
    OZ-T
    Peter North
    British Columbia
    Whatever you do , put them back in backwards
  19. Jan 15, 2013 at 9:14 PM
    AllMountainToy
    Northern California
    got it.. Never understand why they do things a certain way during manufacturing.
    Hartford likes this.
  20. Jan 15, 2013 at 9:16 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
