Cut or Bend...Removing UCA Bolt
Discussion in 'Suspension' started by AllMountainToy, Jan 15, 2013.
  1. Jan 15, 2013 at 9:17 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Bend. I used a set of pilers. Worked perfectly. And was able to bend everything back once done. Looked like it never even happened
  2. Jan 16, 2013 at 4:32 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Suspension goes on before the body i think.
  3. Jan 16, 2013 at 10:11 AM
    AllMountainToy
    AllMountainToy [OP] Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    I figure as much but then ask...why not place the bolt the opposite way to begin with? Oh well
  4. Jan 16, 2013 at 11:45 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    They design autos to assemble quickly. The line counts in dollars per second. There is always a reason but sometimes the reason is "oh crap, what about the...".
    I haven't installed mine yet but I plan to bend and pry.
  5. Jan 16, 2013 at 11:50 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Bend.
    Really simple, probably easier than cutting and replacing and definitely cheaper than buying new bolts!
  6. Jan 16, 2013 at 12:01 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Another reason (though I believe ease of manufacturing is probably the main one) is that if the nut comes off, the bolt is angled so that it won't slip out. When the bolt is placed backwards, if the nut comes off, then there is a greater chance of the bolt working its way out, with the assistance of gravity. Now the chances of the nut loosening up is quite slim...
    Hartford and cory02taco like this.
  7. Jan 16, 2013 at 12:04 PM
    mutilatedjak
    WA
    I bent mine as well
  8. Jan 16, 2013 at 12:07 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    might have to cut the bolts if they are rusted to hell...
    but bending doesn't require additional purchase.
    I'd attempt bending some sheet metal first.
  9. Jan 16, 2013 at 12:10 PM
    AllMountainToy
    Northern California
    really appreciate all input!
  10. Jan 16, 2013 at 12:41 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  11. Jan 19, 2013 at 9:44 PM
    AllMountainToy
    Northern California
    Well....I bent! And as others said it was nothing! Very quick. Did it by myself all returned to normal more or less. Oh and I reinserted the bolt the exact same way. It was way easier to do that then getting it thought all the crap on the other side.
  12. Jan 19, 2013 at 9:56 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How is it easier to not put it in backwards ?
  13. Jan 19, 2013 at 10:07 PM
    AllMountainToy
    Northern California
    With the fuel lines and brake lines as well as the angle you have to take from bottom to top, it just went faster and easier going back the same way.
  14. Jan 19, 2013 at 10:10 PM
    OZ-T
    Peter North
    British Columbia
    Not if you have to take it out next time , haha
  15. Jan 19, 2013 at 10:16 PM
    #35
    AllMountainToy
    Northern California
    True dat. But really each side was easy.
  16. Jan 19, 2013 at 10:17 PM
    #36
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Passenger side went in backwards easy. Driver's side had a fuel line block in the way.
    Thankfully, the part of the inner fender you bend is covered up by the rubber curtains.
  17. Jan 19, 2013 at 10:18 PM
    #37
    OZ-T
    Peter North
    British Columbia
    Huh , I don't remember having an issue , but it was a couple years ago
  18. Jan 19, 2013 at 10:25 PM
    #38
    KenLyns
    Belly of the Beast
    There are some build variations from truck to truck. On my truck, there was almost enough room. In hindsight, I may have been able to get the driver's side bolt in backwards if I cut a few threads off the bolt.
  19. Jan 19, 2013 at 10:29 PM
    #39
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    Bend it and then put the bolts back in the way they came out.
  20. Jan 20, 2013 at 9:08 AM
    #40
    coseng
    coseng Well-Known Member
    Grove City, PA
    2011 TRD DC
    OME 885x front, Dakars rear, LR UCAs, ECGS bushing
    ^^^ This. Did it yesterday. Very easy.
    JayRolla likes this.
