Cut Springs for Add a Leaf?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HelloMyNameIs, Apr 26, 2019.
  1. Apr 26, 2019 at 1:01 PM
    HelloMyNameIs
    HelloMyNameIs [OP] I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    Had a small local shop install 5100s/2885s and a Headstrong 3 leaf add a leaf for me recently. When I picked it up the lady at the desk said the guy had to cut the springs to install the add a leaf, but he was out doing a test drive so I wasn't able to ask him about it. Gonna call later today and ask if he can clarify. Not knowing how to install the add a leaf kit myself, should any part of that process entail cutting the existing leaf pack?
  2. Apr 26, 2019 at 1:08 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Maybe they had to cut off the old bolts? If you live in the rust belt, it doesn't take much.
  3. Apr 26, 2019 at 1:10 PM
    HelloMyNameIs
    I'm in Ohio but the truck is less than a year old so I'd doubt so.
  4. Apr 26, 2019 at 1:15 PM
    bigzm
    bigzm Member
    Zach
    Birmingham
    ‘08 AC Prerunner SR5, ‘18 DCSB 4x4 Sport Inferno
    Inferno-OME/5100 lift, SPC UCA, 265/75r18 Clazzio covers, OEM Audio+,
    When I had a add a leaf installed they had to cut the shackles (if that's the correct term) that held the leaf pack together towards the rear of the leaf pack
  5. Apr 26, 2019 at 1:33 PM
    Sungod
    St Augustine
    Don't forget that it is a Toyota which will rust in the desert.
  6. Apr 26, 2019 at 1:34 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  7. Apr 26, 2019 at 1:37 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    OP, have a pic so we can tell you if everything is good?
  8. Apr 26, 2019 at 1:40 PM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    You have to cut the bracket that’s wrapped around the leaves for for protection on the newer leaf packs to get the 3 leaf AAL installed properly
  9. Apr 26, 2019 at 1:46 PM
    geekhouse23
    I was thinking it was the spring retention clips. Front desk FTW! :thumbsup:
    JS760[QUOTED] likes this.
