cut the middle of factory roof rack good idea?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, May 25, 2008.
  1. May 25, 2008 at 6:48 PM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Hello tacoma community, I REALLY LOVE THE OEM FACTORY ROOF RACK for the db cab, unfortunaly there isn't for my access cab. I have an idea, do you think I can cut the racks on the middle and mount it on the access cab because it's too long, I think I will keep them on running position only.
    Problem is the fixation do you think I can screw on the roof? Thanks guys hope I can adapt it.
    Bryan
  2. May 25, 2008 at 6:56 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I've heard this can't be done.
    In theory it should work, but I am not sure.
  3. May 25, 2008 at 7:10 PM
    bra
    Badges off
    And why it can't be done? Are the db cabs models have already the fixation? Because it will be the only problem for me, I know I must keep them on running position only...
  4. May 25, 2008 at 9:03 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    to mound it on the double cab, there is a front and rear mounting bracket for both sides. each bracket requires two screws, so 8 total. to access these holes (which have welded in nuts on the underside of the roof) you peel off that black rubber stripping on the roof. i don't know if the access cabs have them, but i would check, just peel up the rubber stripping (don't worry, it goes back down very easily) and check for 4 holes on each side. if you have them and they are threaded, i don't see a reason why cutting the middle out of a factory rack wouldn't work.
  5. May 25, 2008 at 10:31 PM
    bra
    Badges off
    Oh yeah it will be so cool to adapt them on an access cab, it will change the totally look, but I've look and I think there isn't fixation on the access cab.
