Cut too much off snout need help
Discussion in 'Performance and Tuning' started by Bfz777, Jun 14, 2021.
  1. Jun 14, 2021 at 2:15 AM
    Bfz777
    Bfz777 [OP] Active Member
    Alistair
    Melbourne
    2009 hilux trd
    Haltech elite 2000, Bosch 1100cc injectors, turbo smart regulator, ceramic coated headers, 2.5 catless free flowing exhaust, rebuild engine kelford cam , kelford valve springs 460ls wilbro pump , rebuild auto with stage 2 valve body, gauges boost afr , 2.5 lift kit with over sized upper arms, trd cai.
    Is there a way around the retaining clip I have cut too much off my snout and can’t get the clip to stay in place .
  2. Jun 15, 2021 at 1:39 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    @Athlaos aren't you running a tiny pulley?
    Athlaos likes this.
  3. Jun 18, 2021 at 10:49 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I took my clip off and have run my pulley for a few years without the clip.
  4. Jun 20, 2021 at 4:47 AM
    Bfz777
    Alistair
    Melbourne
    2009 hilux trd
    Cheers did the cam gears today , next week will port tb and sc inlet then tune for e85
