Cut Weather Stripping, Drill or Remove Entirely and Save for Roof Rack Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RottingShortly, Jul 7, 2023.
  1. Jul 7, 2023 at 5:01 PM
    RottingShortly
    RottingShortly [OP] Member
    Looking for some updated opinions on a roof rack install. 2023
    1. Should I cut them in 3 pieces?
    2. Should I snip the metal and drill aligned holes?
    3. Should I just remove entirely and install the rack without?
    4. Option 4, there is something I don't know about to solve this.
    OEM strips are costly, and I know I have to silicon it ( or if you have a better way)
    If I remove it, what is best to get everything leak proof.
    Aftermarket solutions anyone has seen and or any best practice solutions that's proven?
    Cheers
  2. Jul 7, 2023 at 5:08 PM
    RottingShortly
    For clarity "If I remove it, what is best to get everything leak proof." I meant after, to fill the holes if I removed the rack.
  3. Jul 7, 2023 at 5:11 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Remove, install rack. Don't use silicone. Use Vulcan caulk, or Dap gutter and flashing sealant. Silicone breaks down after time. Cut straps and reinstall using 3m double-sided tape.
  4. Jul 7, 2023 at 6:24 PM
    donp
    donp Well-Known Member
