cuts off after hard acceleration
Discussion in 'Performance and Tuning' started by JadXtreme, Nov 4, 2009.
  1. Nov 4, 2009 at 7:11 PM
    JadXtreme
    JadXtreme [OP] Active Member
    Jamie
    Bladen County, NC
    98 green 4wd ext cab taco. v6 auto
    black headlights/park lights, black bumper, clear turn signals, black euro taillights, Sony cd player, 30 9.50s Federal all terrain tires on stock wheels
    My Tacoma doesn't want to idle after I accelerate hard. Sometimes if I get down on it a couple of times, it will cut off.
    Today for instance: coming home from work, a car was driving slow in front of me. No problem I just mash the gas a little and pass them. A car come over the hill in front of me so to avoid any funny manuavers, I floor it to go ahead and get around the car. My truck's an automatic and I took it up to 70 or till it shifted to 3rd, then slowed back to a cruising speed. A couple miles later I was slowing down to turn down my road and the truck stalled out while I was slowing down to make the turn. At around 15-20 mph while off the gas and braking, it died. It did this everytime I slowed down to make a turn or stop at an intersectioin.
    The problem seems to go away on its own, and is random. If the trucks sits off for a while, it'll go away. Or after 15 mins or so of constant driving, it'll go away. It doesn't do it everytime. It has done this before but works itself out everytime. I drop the truck in nuetral and crank it back up and keep going.
    The truck has 323K miles on it and everything is original. It makes me wonder if some sensor is acting up and if someone could help me diagnos my problem.
    Only performance mod on this truck is a TRD air filter.
    Thanks in advanced.
  2. Nov 4, 2009 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check for vacuum leaks. Around the intake, etc...
  3. Nov 4, 2009 at 7:18 PM
    JadXtreme
    Jamie
    Bladen County, NC
    all the hoses are find and appear to be intact.
  4. Nov 4, 2009 at 7:21 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    MAF sensor need cleaning maybe:confused:
  5. Nov 4, 2009 at 7:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No cracks?
  6. Nov 4, 2009 at 7:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Couldnt hurt.
  7. Nov 5, 2009 at 2:52 AM
    JadXtreme
    Jamie
    Bladen County, NC
    Is that the sensor right behind the air filter?
  8. Nov 7, 2009 at 4:45 PM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    I had the same issue with my truck once.. after it cooled off, It never happened again. Id be curious to find out whats that cause.
