Cutting a Center Pin Bolt w/ a Reciprocating Saw
Discussion in 'Suspension' started by Slim_Shady, Feb 23, 2022.
  1. Feb 23, 2022 at 7:25 AM
    Slim_Shady
    Slim_Shady [OP] Member
    Scott
    2022 Tacoma SR5 - Double Cab - Extended Bed
    Got a Deaver AAL that I want to install. Looks like the only thing I’ll need to cut is the new center pin down to size. Every tutorial I’ve watched used an angle grinder. I’ve got every tool for the job on hand (torque wrench included) other than the angle grander. Half of me wants to go add an angle grinder to the tool box, the other part of me wants to save $$ for more truck parts…
    so first things first: do I even have a choice in the matter. I’ve got a 20v Dewalt reciprocating saw with some Milwaukee torch blades… think this could handle the job?
    six5crèéd likes this.
  2. Feb 23, 2022 at 7:28 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Try it and see, worst thing that happens is you ruin a blade :thumbsup:
    Slim_Shady[OP] likes this.
  3. Feb 23, 2022 at 7:39 AM
    Slim_Shady
    Scott
    Haha or get caught with my dick in my hand and have to hitch a ride to Home Depot.
    six5crèéd[QUOTED] likes this.
  4. Feb 23, 2022 at 8:24 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Reciprocating saw sounds a little sketchy for that job, I'd rather use something with some more precision to it. IMO an angle grinder is an essential tool in the shop so I'd be tempted to use this as an excuse to buy one. It doesn't have to be a nice or expensive one. I've actually had great luck with the cheap Harbor Freight angle grinders. In my limited experience (having only owned 3 angle grinders), my HF one is as good, or better, than the Porter Cable ones that I spent 2-3x on.
    Another option (if you have an air compressor) would be to buy an angle die grinder (again, I'd recommend Harbor Freight).
    Either way, you're probably looking at a total cost of $30-40 for tool, discs and tax. Money well spent IMO.
    wi_taco and Slim_Shady[OP] like this.
  5. Feb 23, 2022 at 8:27 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Hacksaw and should not take more than a minute to do both. Leave about a 3/16-1/4" extra than with a ball peen hammer peen over the remaining above the nut to ensure the nut stays in place.
  6. Feb 23, 2022 at 8:41 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Ive used both dozens of times. Sawzall works fine. Probably get a little cleaner cut for the threads with a grinder, but as long as you have the nut cinched before the cut youll be fine.
  7. Feb 23, 2022 at 9:22 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Sawzall blades will work fine for that. Now if you ever have to install a 3 leaf add a leaf and you have to grind off the giant rivet on the OEM leaf pack then you def want the grinder for that.
