Cutting Bedsides For HC Bumper ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MolonLabeTaco, Jan 8, 2020.
  1. Jan 8, 2020 at 3:53 PM
    MolonLabeTaco
    MolonLabeTaco [OP] Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Cutting my buddy's bed for his HC bumper soon. I have a grinder w/a cut-off wheel, jigsaw w/a fine tooth metal blade & a sawzall w/a fine tool metal blade. It seems most use a cut-off wheel on a grinder but why not a jigsay w/a fine metal blade? Seems the jigsaw would make a much nicer cut w/less chance off getting off the 2 foot long line.
    Yes/no?
  2. Jan 8, 2020 at 3:55 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    The teeth of those blades even the fine toothed ones can grab the metal and mess it all up bad. A cutoff disc and steady hands work really well. Also tape the cut line and a bit above it with painters tape. Quadruple check your measurements.
  3. Jan 8, 2020 at 3:57 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    What do people use when the trim their fenders, in an arc, for larger tires?
  4. Jan 8, 2020 at 3:59 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    cutoff wheel then flap disc to get it evened out. Takes a smooth hand
  5. Jan 8, 2020 at 4:00 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Grinder works great with minimal to no paint damage if you take it slow and easy, thats what i did on mine. And i would love to see someone use a jigsaw on flimsy sheetmetal and make anything resembling a straight line.
    wmgeorge and MolonLabeTaco[OP] like this.
  6. Jan 8, 2020 at 4:01 PM
    tigertownalum
    tigertownalum Well-Known Member
    Trey
    G-Vegas, SC
    2017 Tacoma TRD OR DCSB Inferno
    There seem to be lots of videos out there on this. Check the bumper manufacturer and see if they have a video on youtube. Could be really helpful.
  7. Jan 8, 2020 at 4:01 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I've cut ~6 trucks bedsides for HC bumpers and used an angle grinder each time. To trim my fenders for larger tires, used a jigsaw. You have to go extremely slow with the jigsaw and it's easy to get off the line. I can make a damn near perfect HC cut with an angle grinder.
    My trick is (after the line is drawn) start cutting extremely slow, barely any pressure. Not enough to cut through, but enough to scribe a line in the metal. Once you have that line, then make another pass, cutting all the way through. The scribe helps keep you on track.
    edit: And I use a 6" disc and cut straight through the fender flare, down to the fender. Much much easier than removing the flare, and still makes a perfect cut.
  8. Jan 8, 2020 at 5:20 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I wish!
  9. Dec 13, 2020 at 8:18 PM
    TacoTuesday1
    FL
    what model angle grinder?
  10. Dec 13, 2020 at 10:58 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  11. Dec 13, 2020 at 11:02 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    if you have a nice sharp find metal blade the jigsaw will work well. That is what I used when trimming fenders. As others noted they can grab and bend the sheet metal easily but if you catch it its not bad. I generally noticed then when the blade started to do dull. Generally after the first fender or so. If you have good control over the cut-off wheel it works. I had someone install my bumper when I picked it up. It was a decent job. I feel I could have done better with the jig saw but overall both methods work. The cut off wheel chipped some of the paint and sometimes getting an even cut can be tough but depends ho good you with it.
  12. Dec 13, 2020 at 11:04 PM
    nudavinci64
    Robert
    def would 2nd that by making a scribe. biggest mistake is going at it with a grinder too fast.
    EatSleepTacos[QUOTED] likes this.
  13. Dec 13, 2020 at 11:38 PM
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    A jig saw will vibrate the crap out of your material and make a mess of things. I used a Dewalt cordless angle grinder with a cutoff wheel and it did great. The first issue was the fender flare is a little deep for a 4.5" disc. The other problem being the grinder melts the flare while it cuts. I would highly recommend using just the grinder, but with a 6" disc. Also have some color matched touch up paint for the edges
    Mark77 likes this.
  14. Dec 13, 2020 at 11:39 PM
    j8food
    Jay
    I used a q-tip to paint the open edges and protect from rust. I also put some edge trim on to complete the look.
    You should also cut the exhaust just after the rear axle (I assume in Texas this is fine, in cali im afraid I might not pass smog with a modified exhaust)
    My best advice is to take your time and tape/mark it all before cutting anything. You can only cut once so measure thrice. If you have more questions feel free to PM me. I've got a 2009 with BruteForceFab HC rear bumper I installed solo in my driveway.
    Jmac2408 likes this.
  15. Dec 14, 2020 at 12:21 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Think you could get away with a slip on joint?
    Slip it when you have to smog and pull it off when you're rolling?
    I cut my fenders with a Air Body Saw and a very fine tooth blade, took my time went very slowly then cleaned up with a flap disk on a 4" grinder.
    When I do my bed sides I'll do the same except as I saw Brian do at Windrock, cut about 1/2-3/4" below where I want the line then carefully roll it up so I have a nice curved lip with a little rigidity rather than a floppy jagged razor edge.
    Looked clean and was done great.
  16. Dec 14, 2020 at 12:37 AM
    j8food
    Jay
    It's all about the visual inspection here. If the tech doesn't care it's fine, but if they do I'll be in for a retest. We have the strictest laws in the country regarding smog checks and since Dominic Toretto hit the scene its only gotten worse. If your car isn't completely stock they can fail you just on a visual inspection.
  17. Dec 14, 2020 at 2:29 AM
    Key-Rei
    Key
    Florida
    Wow that's kind of pants on head retarded.
    Like seriously. Lopping off 12" of pipe doesn't change the emissions, or even the sound for that matter it's after the muffler...
    Thank God I life in the DGAF state where we have the coastal jetstream to magically dissapoof all emissions.
  18. Dec 14, 2020 at 4:00 AM
    j8food
    Jay
    Yeah, its super lame here. Technically we are supposed to use oem exhaust parts only. Its making it hard to even get motorcycle exhausts even though they don't have to get smogged.
