Cutting fender liner clips
Discussion in 'General Tacoma Talk' started by Hogsnatcher, Dec 31, 2023.
  1. Dec 31, 2023 at 2:42 PM
    Hogsnatcher
    Hogsnatcher [OP] Member
    2013 Tacoma Sport - Long bed
    I’ve decided not to spend my time prying out the clips and would rather just cut them out and replace with new ones. What’s the best way to do this?
  2. Dec 31, 2023 at 3:03 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Getting a blade underneath the clip lip to cut/saw the clips may be harder than just prying them out once you get a gap started.
    There are a couple of clips you can reach the backside from inside the engine compartment and take a side cutter to.
    I did not have any luck salvaging any clips no matter what methods I tried.
    koditten likes this.
  3. Dec 31, 2023 at 3:05 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    A sharp razor will take the fender side of the clip off. If that doesn't work a set of dykes cutting off the inside portion works as well.
  4. Dec 31, 2023 at 3:30 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    This works great when you have room.
    Like said above, I don't try to save them and just side cutter them off.Bivethoi 3 Pack Stainless Steel Wire Saw Emergency Saw Kit, Camping Wire Saw Mini Backpacking Saw, Cable Cutting String Bone Rope Saw, Travel Chainsaw for Wood Cutting Hiking Hunting (Plastic Handle) https://www.amazon.com/dp/B09VP9MRHV
