CUTTING FLUSH MOUNT PODS INTO REAR BUMPER
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tbraumb11, Jan 5, 2021.
  1. Jan 5, 2021 at 9:04 PM
    tbraumb11
    tbraumb11 [OP] Well-Known Member
    nanaimo
    2015 tacoma double cab magnetic grey
    what are those?
    So I spent too much money lately on the truck and decided I will hold off on a new rear bumper for next year.
    I got a set of cheap flush mount pods that I want to cut into my stock rear bumper and run to its own switch in the cab to tide me over its got a dent from when I bought it anyhow so not worried about resale.
    I have limited tools while I am living with my girlfriend for the time being during covid, was wondering what the best tool would be to cut into the rear steel bumper for the cutout. I will have to rent/buy/borrow something I only have the basics on hand or no tools with a cord I should say.
    Anyone done this with success and if so what did you use to cut into the bumper?
  2. Jan 5, 2021 at 9:05 PM
    tbraumb11
    nanaimo
    what are those?
    oh yea its a MGM painted sport bumper with tow package if that makes a difference.
  3. Jan 5, 2021 at 9:12 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    The metal of the stock bumper is thin and chincy I would make a template then drill the mount holes first then drill the main opening corners stepping up to a 1/2" then use a jig saw to cut the main opening and clean up with a die grinder as necessary.
    That's what I did with my 3/16 plate rear, would be dumby easy on the stock bumper.
  4. Jan 5, 2021 at 9:19 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Exactly what I did on my 07 Taco and 08 Tundra. Except I did the edge cleanup with a file.
  5. Jan 5, 2021 at 9:31 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I did the same. Drilled holes in all four corners and used a dremel/angle grinder to cut it out. Pretty straightforward. Just look behind where you’re planning to cut so you don’t add a hole where there’s bracing or wires for your tow harness.
    Key-Rei likes this.
  6. Jan 5, 2021 at 10:09 PM
    Key-Rei
    Key
    Florida
    Also not a bad idea to cover larger area in painters tape to protect the finish some.
    Sterling_vH111 and tbraumb11[OP] like this.
