Cutting grill bars for lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by claw, Jul 9, 2011.
  1. Jul 9, 2011 at 10:52 PM
    claw
    claw [OP] Well-Known Member
    Cam
    Bozeman MT
    2010 Access Cab, 4 Banger
    Tonneau cover, bed lights, fog lights, VHF radio
    Hello everyone,
    I'm wrapping up my masters dissertation on Monday and I'm hoping to celebrate by installing these lights I have from PIAA in my grill. They are about half an inch to tall, so I am planning on taking a dremel and sand paper to the grill bars to recess the lights in. I haven't seen anyone on here do it before. I have two questions: 1) Removing part of the grill in this fashion won't provide a catastrophic failure somehow, correct? and 2) Any good ideas on mounting? I could make an mounting bar out of angle iron and attach it to the radiator mount(??) or could the grill bars themselves actually work?
    Thanks for any thoughts, I want to try and get this checked off my to do list this week but also don't want to fubar my grill.
  2. Jul 9, 2011 at 11:06 PM
    Beerrun
    Beerrun Well-Known Member
    Jon
    Spokane WA
    10 Sedan Sport LB
    Fog light rewire- debadge- front window tint- 5100's @ 1.75- Toytec 1.5 AAL- Avid sliders- 4x4 lighted switch- Sockmonkey decals- Truxedo low pro QT cover- Weather Techs- Back up light Mod. Diff. breather mod. OEM roof rack-Yakima bars. HomerTaco grill. Hella Black Magic Lts. WT vent visors.
  3. Jul 9, 2011 at 11:22 PM
    claw
    Cam
    Bozeman MT
    How can I post pictures of something not yet done? I haven't even seen anything quite like it...
  4. Jul 9, 2011 at 11:24 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OP , you intend to cut out the grill crossbars to mount lights ?
  5. Jul 9, 2011 at 11:26 PM
    claw
    Cam
    Bozeman MT
    Yes. Only more of take out a quarter of an inch by 4 inch pass to fit the lights into.
  6. Jul 9, 2011 at 11:31 PM
    claw
    Cam
    Bozeman MT
    Maybe this will help... In the top is one side of the grill as stock. The middle would be cutting a spot for the light between the two horizontal cross pieces, and the bottom image would be the same thing but between the top two where there is a little more room (less cutting)
  7. Jul 10, 2011 at 7:39 AM
    claw
    Cam
    Bozeman MT
    Bump for any help. The more I think about it I want these in between the two cross bars in the middle just to keep it looking better.
  8. Jul 10, 2011 at 10:55 PM
    Beerrun
    Jon
    Spokane WA
    10 Sedan Sport LB
    [​IMG]Something like this? I thought about this before, cut the horizontal bars and fiberglass rings into the grill to mount lights. Lot of work but it could be sweet.
  9. Jul 11, 2011 at 12:46 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    I wanted to do that as well, but I figured epoxy and body filler on flexible plastic parts would not live as long as the OEM part, so I gave up. I'd like to see this one being done!
  10. Jul 11, 2011 at 1:03 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  11. Jul 11, 2011 at 7:07 AM
    claw
    Cam
    Bozeman MT
    Beerrun: Yes, something very similar to that is what I'm shooting for, only I'm using the PIAA 2100 lights which are rectangular instead of round.
    Wolfpack: No, I wouldn't.
    Everyone else, thanks for the interest! I'm hoping that since I only am removing 1/4" from each cross bar the structural integrity should be comparable.
    I was also thinking about mounting to the top of the cross bar which is molded as it seems approximately as stiff as any other mounting point in that area. Otherwise it seems I would be mounting a large cross bar, securing it to the vertical support in the middle of the grill, and still having to come forward to have the lights in the proper location. Unless I use some very rigid materials it seems that would flex about the same as the grill piece.
    Any other thoughts? I defend for my MS today so we'll see how much time I have later this week and this weekend.
    Thanks!
  12. Jul 11, 2011 at 10:01 AM
    DubyaDawg
    DubyaDawg Underprepared and Overconfident
    Tulsa/Norman, OK
    2010 DC PreRunner TRD Sport
    Avid Light Bar, KC Dayliters, Roll-N-Lock bed cover, TRD Center Caps, Fog Light Anytime Mod.
    I think this would look awesome if you can figure out how to do it, also props for trying something different!
