Cutting larger hole in Budbuilt skids (oil drain)
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Jan 11, 2016.
  1. Jan 11, 2016 at 7:37 AM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    The oil drain hole for my BudBuilt is entirely too small (about 1.5"). Well I went to change my oil Saturday and apparently the skids are positioned a little too far forward last time I put them on, so the oil draining out was hitting the edge of the oil drain hole and allowing it to flood all over the place, all over the skid and all over the pavement. A huge mess... I had to go to the Walgreens and get kitty litter and ended up using the entire container.
    Anyways, I got a hole saw at Lowe's, its one of those Lenox "Bi-Metal' hole saws. I got the 2.5" hole saw and was wondering if any of you guys had tips for cutting the skids. I'm guessing I will need a cutting fluid. Will 5w-30 oil work as a cutting fluid?
    Thanks!
  2. Jan 11, 2016 at 7:57 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    No, there is a product machinists use called, appropriately, 'cutting oil' . I always use it when drilling holes. Facilitates cutting as well as cooling.
  3. Jan 11, 2016 at 8:05 AM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    Yes, motor oil will suffice as cutting oil for one hole. Sure if your going to be doing a lot of fab work true cutting oil might be best, but motor oil will work.
    No matter what you use, use a lot of it. A steady stream/trickle onto the cutting surface.
  4. Jan 11, 2016 at 8:15 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I would use a variable speed drill motor.
    Slow speed will help save the teeth during the process.
    If the skid plate is off the truck place a smaller hole saw inside the bigger one that will fit inside the original hole to keep it centered.
    Slow and steady is your friend.
  5. Jan 11, 2016 at 8:26 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    I think you mean for him to first put a hole saw that is the same size as the existing hole (1 1/2") on the collet, then put the
    2 1/2" saw (or even 3") on the collet and lock them both down. I've never tried that before, but if it works, I like it!
    Good thinking! :thumbsup:
  6. Jan 11, 2016 at 5:25 PM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    I put the big hole saw on first and then thread on the smaller one if you have enough threads left.
    I would not bother with any cutting fluid, if you hold good pressure on it and go slow speed you should be fine.
    I have drilled a crapload of holes in my time.
  7. Jan 17, 2016 at 4:05 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah I'm just gonna take an angle grinder to this bitch and cut a square.
  8. Jan 18, 2016 at 7:17 AM
    capturecolorado
    capturecolorado Well-Known Member
    Alex
    Grand Junction, CO
    01 4Runner SR5 with some things attached
    I support the idea of cutting a round hole.
    What I would do, and have done in the past when needing to enlarge a hole w/ holesaw:
    Track down a scrap piece of 3/4" lumber that's a little wider than your desired hole size (say, 5"). Ideally a hardwood, if not, consider 3/4" ply.
    Cut the lumber to size so that you can clamp the lumber to the skid, or whatever material you may need to drill the hole in.
    (before clamping) Drill your larger hole in the lumber, this is your guide.
    Clamp lumber securely to skid with guide hole centered over the original hole as you desire.
    Drill the hole w/ hole saw. Traditionally (as we all know here) your 1/4" bit in the center of the hole saw is guide for the whole arrangement, but if you're enlarging an already formed hole, you need some way to keep the saw stable and centered. I've used this method often with great success. If you're drilling through 3/16"+ material, I would definitely use some kind of oil, it'll prolong the life of your saw or bit, reduce the stress on the drill, reduce the heat buildup, etc. You can pretty much use whatever oil you have (not DOT!) sitting around if you're just doing a couple of holes.
    crazy joker likes this.
  9. Jan 18, 2016 at 7:22 AM
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
  10. Jan 18, 2016 at 1:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I agree with this. ^^^
    There is a good reason why Bud did not make those holes bigger. It will be much easier to catch on something with the larger opening and when you do, it will really mangle or possible tear the skid. And the larger opening only tends to weaken the structural integrity of the skid.
    My $0.02
  11. Jan 18, 2016 at 3:33 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Take it off make a plate that bolts to welded nuts on the top of the skid plate .
    You could even counter sink the bolt heads so they don`t get beat up.
    Time for oil change remove the plate .
    Replace with new hardware if it is to beat up
  12. Jan 18, 2016 at 6:34 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah, I know what y'all mean. Though I have seen some other people making skids with really big holes for the oil drain. I ended up cutting a square. If it fucks me up on the trail, I'll just have to get a new skid or have a plate welded over it and start over.
