Cutting LCA Cam Bolts out
Discussion in '1st Gen. Tacomas (1995-2004)' started by Green1GT, Nov 16, 2021.
  1. Nov 16, 2021 at 3:24 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    My sleeves popped out without any issue
    I dunno how I won that lottery
  2. Nov 16, 2021 at 3:25 PM
    Green1GT
    Green1GT [OP] Well-Known Member
    Maryland
    Where you from?
  3. Nov 16, 2021 at 3:26 PM
    JKO1998
    Utah
    Northern Utah
    Rust country
  4. Nov 16, 2021 at 3:28 PM
    Green1GT
    Maryland
    That's surprising. Do they salt the roads out there? I've got a buddy out in Boulder who's got a 3rd gen who says they don't.
  5. Nov 16, 2021 at 3:28 PM
    JKO1998
    Utah
    The frame of my 99 begs to differ
    Green1GT[QUOTED][OP] likes this.
  6. Nov 16, 2021 at 3:29 PM
    Green1GT
    Maryland
    Haha ok I feel you on that one. Buying a first gen = learning how to weld
  7. Nov 16, 2021 at 3:31 PM
    JKO1998
    Utah
    I went with
    buying a 1st gen from a rust free place
    Like southern Utah and keeping it clean
    Approach
    MalinoisDad likes this.
  8. Nov 16, 2021 at 3:32 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yeah, having the right coil springs and setting the 5100s back down to the stock setting should do a lot for the ride.
  9. Nov 16, 2021 at 3:32 PM
    Green1GT
    Maryland
    Party pooper
    Lol
  10. Nov 16, 2021 at 3:32 PM
    4ast4orward
    4ast4orward Well-Known Member
    WA
    2014 Tacoma DCSB 4x4
    Just did this a month ago diablo metal blades are the way to go, also use a cutting fluid too make the blade last longer and make it cut faster and smoother I used wd 40. It wasn't as bad as I thought it was gonna be maybe 15 mins of cutting with my Ryobi compact reciprocating saw and 2 blades total.
    Green1GT[OP] likes this.
  11. Nov 16, 2021 at 3:33 PM
    Green1GT
    Maryland
    Awesome. I've got a big bosch corded sawzall. Should make quick work of them with those diablo blades and fluid like you said.
  12. Nov 16, 2021 at 3:35 PM
    jbrandt
    Justin
    yep. But not cause rust! :D
    Green1GT[QUOTED][OP] and JKO1998 like this.
  13. Nov 16, 2021 at 3:36 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I got MOOG LCAs for like $100 ea on Amazon. Well worth the hassle of trying to burn out and press and fight and just end up with crappy Polyurethane bushings (hate em!)
    Also try and use OEM cam hardware. Nothing aftermarket is any good.
  14. Nov 16, 2021 at 7:03 PM
    Green1GT
    Maryland
    Need to take on more "fun" welding projects. I think next up is a spare tire carrier mounted to the bumper
    jbrandt[QUOTED] likes this.
  15. Nov 16, 2021 at 7:05 PM
    #35
    Green1GT
    Maryland
    Yeah I ordered the cam bolts from my local Toyota dealer. I'm probably just going to keep the old LCAs. Spending $200 or more not totally necessarily is not exactly in the budget of broke college kid who works one day a week lol.
  16. Nov 16, 2021 at 7:06 PM
    #36
    Green1GT
    Maryland
    But what do you hate about the poly bushings?
  17. Nov 17, 2021 at 7:20 AM
    #37
    ZColorado
    13 DCSB OR 6MT
    They always fail much much sooner then rubber and squeak. They are heavily marketed as "better" but thats mostly because they are cheap and easy to produce in any shape and size. Rubber lasts longer, absorbs bumps and vibration better.
  18. Nov 17, 2021 at 9:00 AM
    #38
    jbrandt
    Justin
    "always"?
    Interesting superlative you used here.
    I've been running the same poly bushings for almost ten years and not once have they squeaked or wore out.
    Like anything, they have advantages and disadvantages compared to stock that depend on your use case.
    For me, the fact that they theoretically transmit more vibes in my 17 year old pickup truck is barely noticeable, and the fact they can rotate without binding means they don't limit the travel on my mid-travel setup.
    Bivouac and ZColorado[QUOTED] like this.
  19. Nov 17, 2021 at 10:06 AM
    #39
    ZColorado
    13 DCSB OR 6MT
    fair point, That may have been a bit extreme. I dont want them on my vehicles though.
  20. Nov 17, 2021 at 10:41 AM
    #40
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have no complaints With my Home Made Poly bushings at 100,000 miles plus on 21 year old truck nor the ones installed on my mid eighties Toyota 4x4`s
    I will agree cheap and easy to make !
