Cutting my Truck
Discussion in 'General Tacoma Talk' started by SlippRott, Sep 24, 2024.
  1. Sep 24, 2024 at 5:38 PM
    SlippRott
    SlippRott [OP] Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    I'm about to install a new front bumper from ADD (Honey Badger) and I need to cut the front fenders. I don't want to "F" it up and I'm a little nervous. (It's a clean 22 OR - for now)
    What is the best tool to make the cut? Cutting wheel? Recip Saw? Other?
    Any advice from experience on what to do / not to do? I know you guys have a lot of experience.
    (I know, I know, I am just going to get it scratched up anyway. I need to get over that also but first I need to get the bumper on)
  2. Sep 24, 2024 at 8:12 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    osillating multitool
    Blacktail 8541 likes this.
  3. Sep 24, 2024 at 8:13 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    Make sure to measure once and cut twice.
    Knudsen, SR-71A and ToyoTaco25 like this.
  4. Sep 24, 2024 at 8:33 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
  5. Sep 25, 2024 at 12:51 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Ignore @Jakerou ... his truck is nicknamed "swiss cheese". :facepalm::crazy:
  6. Sep 25, 2024 at 1:05 AM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Put masking tape down before you cut to protect the paint and minimize any accidental scratches.
  7. Sep 25, 2024 at 8:47 AM
    SlippRott
    22 Silver OR
    Is that really going to do a good job on the painted part of the fender? Looking at some video's I've seen them use that on the inner black fender liner which is thinner but it seems most use a Dremel or larger cutting wheel for the actual painted fender.
  8. Sep 25, 2024 at 9:08 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    +1 on the tape, it should reduce cracking on the part you keep. You can also draw your lines on the tape so you have something to cleanly trace for the cut.
    One of the larger round blades for an oscillating multi tool is effectively a cutting wheel that doesn't try and get away from you (don't know if you know, but these were invented for cutting casts off of peoples limbs, without cutting the person). I haven't used one on a vehicle, but they are far and away the best tool for cutting something on your house, where you don't want to cut anything else by accident.
    A professional fabricator could likely do a better (faster?) job with a grinder and cutoff wheel, but your average Joe would just fuck something up. A dremel will give more control, but there is still the chance is gets away from you.
  9. Sep 25, 2024 at 9:26 AM
    SlippRott
    22 Silver OR
    Yeah, i could see how an oscillating multi tool may be better from the aspect of not getting away from you. I guess if it'll cut baseboards and everything else I have used it for there is no reason is should not work on the plastic bumper. I do need to see if I have a roundish tool though, that would be helpful also.
  10. Sep 25, 2024 at 9:37 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I use simple jigsaw with a fine tooth metal blade. Cutoff wheel can put more heat into paint than saw blade. Watch out for what is behind you cuts.
    Make sure tape covers area where base of saw will touch. While cutting, keep base pressed to truck so it isn't hammering but also careful base doesn't tear tape and leave scratches as you go.
    Deburr edges when done. I like to use a worn out sanding disc on my angle grinder to gently smooth the edges.
  11. Sep 25, 2024 at 9:37 AM
    OffroadToy
    Also works great for shortening up mud flaps. :thumbsup:
  12. Sep 25, 2024 at 12:06 PM
    SlippRott
    22 Silver OR
    So this is what the guy at ADD mentioned, a jigsaw. I think I am most comfortable with a Jigsaw, I just did not think there was enough room underneath for the reciprocating blade but since you mentioned it also there must be.
  13. Sep 25, 2024 at 12:10 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ADD Honey Badger requires cutting the metal fender? Really? Pictures show you cut the plastic bumper cover and the plastic fender flare that extends past the bumper line.
  14. Sep 25, 2024 at 12:10 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Maybe. You'll have to look. I was thinking more in general about cutting body panels. I don't know for certain about that specific bumper you have.
  15. Sep 25, 2024 at 12:14 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I feel like a jigsaw is just going to go apeshit on the plastics and push/pull as compared to a cutting disc.
    I’ve done it in a 4Runner with a utility blade just making multiple cuts, then sanding smooth up to like 1000+ grit.
  16. Sep 25, 2024 at 12:16 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  17. Sep 25, 2024 at 12:19 PM
    Jim727386
    Jim727386 Well-Known Member
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Plain Jane - Bare bones
    If you're cutting plastic, I would use an oscillating saw with the only blade from Harbor Freight that is decent. I have cut plastic, wood, metal with this thing. The rest of harbor freight blades are junk IMHO
    OffroadToy likes this.
  18. Sep 25, 2024 at 12:22 PM
    SlippRott
    22 Silver OR
    No metal, just plastic, but either way I don't want to F it up. I've put so much work into this truck, I am just trying to figure out the best method for best results.
    Stuck in VT likes this.
  19. Sep 25, 2024 at 12:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^For plastic a body saw is best (small reciprocating saw easier to control than sawzall). I've used a cutoff wheel with passable results - the heat causes "hair" and melted plastic globules to form on the cutting edge, which has to be sanded smooth.
    Since lower part of the bumper will be discarded after cutting, you can make practice cuts there until you're satisfied with the tool/technique.
  20. Sep 25, 2024 at 1:48 PM
    RichochetRabbit
    Good idea. If the first cut does not work and you need a new tool, you can live with the small corner error for a couple of days.
