Cutting my Truck
Discussion in 'General Tacoma Talk' started by SlippRott, Sep 24, 2024.
  1. Sep 25, 2024 at 2:08 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I did my plastic bumper removal in two steps. First I did a “viper” cut to test my skills with the oscillator saw. Knowing full well I was going to remove most all of the bumper later for a winch so nothing would matter either way. Both worked out great. No problems.
    My vote is for the oscillator and practice cuts with masking/painters tape.
  2. Sep 25, 2024 at 6:41 PM
    SlippRott
    SlippRott [OP] Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    Good idea
  3. Sep 26, 2024 at 10:13 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've used jig saw, dremel, and cutoff wheel... they make a rough cut and the heat melts the plastics/plexiglass. The ossilating tool is the way to go.
    and don't get me started on harbor freight zip ties!! :annoyed:
    I-Give-Up and Jim727386[QUOTED] like this.
  4. Sep 26, 2024 at 10:20 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I just used a cutting wheel on the metal and an oscillating tool on the plastic parts. A nibbler would be best, that is what auto body shops use, but a good one (that drill attachment nibbler looks pretty janky and awkward). The edge is covered with trim, so if it isn't perfect you won't see it. Most important is getting your measurements right.
