Cutting out above 3000 rpm
Discussion in '1st Gen. Tacomas (1995-2004)' started by JShoot, Jan 11, 2010.
  1. Jan 11, 2010 at 2:59 PM
    JShoot
    JShoot [OP] Member
    Texas
    2000 SR 5 4x4
    I purchased my 2000 Taco with 194,000 miles on it, I've put 2,000 miles on it. It runs fine unless I get it over 3,000 rpm's, at that point it has a hesitation or pause, then will pick up and go. The truck is a V6 model, standard. Does anyone have any idea's what is wrong. I was told by the dealer I bought it from that they changed the timing belt at 161,000 miles and one of the CDI boxes (??) was changed at 190,000. Any suggestions would be greatly appreciated.
    Thanks,
    J.Shoot
  2. Jan 11, 2010 at 3:40 PM
    blackxpress
    blackxpress Well-Known Member
    Jeff
    Carlisle, OH
    98 SR5 2WD Xcab
    No check engine light?
  3. Jan 11, 2010 at 4:10 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Could be a coil, or a MAF sensor. With out a CEL it's gonna hard to determine the problem over the internet.
  4. Jan 12, 2010 at 4:39 AM
    JShoot
    JShoot [OP] Member
    Texas
    2000 SR 5 4x4
    No check engine light.
  5. Jan 12, 2010 at 5:23 AM
    JShoot
    JShoot [OP] Member
    Texas
    2000 SR 5 4x4
    No the truck is all stock.
  6. Jan 12, 2010 at 5:32 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It could be a fuel system issue as there really aren't too many CEL's for that. Maybe the Fuel Pressure Regulator is dropping out or maybe the fuel filter needs changed or maybe a vacuum leak.
    To check for a vacuum leak, get a propane torch and turn it on (don't light it). You just want the gas to come out. Point it at your vacuum lines. If there is a leak, the engine will start to rev higher.
    The Fuel filter is under the left side cab on the frame rail.
    The check the FPR, you can pinch off the return line and see if you can duplicate the "engine stumble" above 3k RPM.
  7. Jan 12, 2010 at 12:59 PM
    JShoot
    JShoot [OP] Member
    Texas
    2000 SR 5 4x4
    Thanks for the suggestions. I'm fixing to get started trying to figure it out. I will start with the easiest things and go from there.
    I really didn't think it was fuel because the truck is still getting 17-1/2 mpg and that's 70% of all the driving in 1st or 2nd gear on the ranch.
    But, I really don't know so I'll keep everyone posted on what it turns out to be.
    Thanks everyone...
  8. Jan 12, 2010 at 3:01 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    have you cleaned the MAF?
  9. Jan 13, 2010 at 4:27 AM
    JShoot
    JShoot [OP] Member
    Texas
    2000 SR 5 4x4
    No I haven't, thanks for suggestion.
  10. Jan 13, 2010 at 8:09 AM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    might be a fuel pump? my buddy just had his fuel pump go out and it would bog down right at 3k rpm
  11. Jan 13, 2010 at 9:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^^^^
  12. Aug 30, 2017 at 2:31 PM
    Bama_Noles14
    Bama_Noles14 Member
    Jonathan
    1997 Toyota Tacoma 4x4 3.4L
    Gonna try that this weekend
