Cutting super bumps
Discussion in 'Suspension' started by wiggler, Sep 25, 2021.
  1. Sep 25, 2021 at 7:50 PM
    wiggler
    wiggler [OP] Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    So I have been feeling like my super bumps are limiting my up travel too much. More so in the front. Sometimes going over small hills I fear I am gonna roll over.
    Anyone ever cut them down?
  2. Sep 26, 2021 at 1:08 PM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    I'm pretty happy with my fronts, but I plan to trim a bit off my rears. I'm loosing @ an inch of up travel in the rear
  3. Dec 10, 2021 at 11:34 AM
    jonnytacoo
    jonnytacoo Well-Known Member
    Jonny
    So Cal
    2018 TRD Off-Road 4x4
    OEM
    Yeah I’m only using half my shock also I was wondering about this. Sitting on the bumps and only using half the rod maybe less. Doesn’t seem like the right setup. They make you lose up travel or bump travel. How did you guys cut them?
  4. Dec 10, 2021 at 11:43 AM
    wiggler
    HILO
    Hack saw
    jonnytacoo[QUOTED] likes this.
  5. Dec 10, 2021 at 11:49 AM
    jonnytacoo
    Jonny
    So Cal
    OEM
    how much did you trim off and how?
    I’m worried trimming mine with make them fall apart super fast maybe not lol could just take a hand saw to them
  6. Dec 10, 2021 at 11:50 AM
    jonnytacoo
    Jonny
    So Cal
    OEM
    How much you trim off?
    did it make them more suspectible to wear? Or is the material the same inside
  7. Dec 10, 2021 at 11:53 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    I actually went the opposite direction and added a 3/8 in spacer to the bump stop but mainly to reduce rubbing with the 35's. Also, do you still have the sway bar connected upfront reducing travel?
    Island Cruiser likes this.
  8. Dec 10, 2021 at 1:47 PM
    wiggler
    HILO
    Took about an inch off. Material is the same inside but it’s of course not smooth anymore. Been off road several times since and like look the same. Can’t say about the long term. I have Took out my sway bar a while back
    jonnytacoo likes this.
  9. Dec 12, 2021 at 5:56 PM
    TVH475
    Montrose CO
    I haven't cut mine yet, it's low priority on the list, but I'll use a sawzall
  10. Dec 12, 2021 at 8:28 PM
    wiggler
    HILO
    be careful.. how you gonna clamp it or secure it. I speak from experience.. coulda lost a finger when I first tried to cut mine on a 14” bandsaw. The rubber really takes a grip. Hack saw will take 15 minutes max for all four.
  11. Dec 12, 2021 at 9:55 PM
    jonnytacoo
    Jonny
    So Cal
    OEM
    I cut about 1/2 “ off it felt so much better in the dirt and on the road
    oh and handsaw didn’t take long. Fine tooth one.
  12. Dec 12, 2021 at 9:58 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I went back to stock for the same reason. In the rear I was pounding the bumpstops all day. Back to stock and no more bottoming out.
  13. Dec 13, 2021 at 5:38 AM
    TVH475
    Montrose CO
    Thank you for the advice! I was thinking I'd just pull the tires off & cut them on the truck
