Cutting tip off of TRD catback exhaust
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tbrooks2444, Aug 29, 2019.
  1. Aug 29, 2019 at 2:59 PM
    Tbrooks2444
    Tbrooks2444 [OP] Well-Known Member
    I purchased the trd catback exhaust for my 2019 dclb when I got the truck, and I love it. I like the sounds it produces when I mash the pedal. I’m installing kings all around and a custom Alcan pack for 2” of lift with 500lb capacity over stock. I’ll also be installing archivegarage hammer hangers when they arrive. Will the leaf pack contact the exhaust pipe under full droop off-road? Should I cut the end off of it? Would it be a waste of that exhaust to cut the trd end off of it? Should I just put the stock exhaust pipe back on and cut that one instead? Thanks!
  2. Aug 29, 2019 at 3:37 PM
    NWTacoTime
    NWTacoTime Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
    I have the TRD Catback and just installed Kings 2.5 all around with a leaf pack and everything is fine. You should be good
  3. Aug 29, 2019 at 3:54 PM
    Tbrooks2444
    Hey man thanks for the response. I guess we will see.
  4. Aug 29, 2019 at 5:08 PM
    NARCOSIS
    NARCOSIS Member
    Every truck is different load you carry tire wheel size and offset .... i wouldn’t cut anything until after everything is installed and then check ....worst case is it hits just every now and then when really off-roading
