cutting wire at factory tweeters?
Discussion in 'Audio & Video' started by tacomaniacmatt, Oct 14, 2013.
  1. Oct 14, 2013 at 5:34 PM
    tacomaniacmatt
    tacomaniacmatt [OP] Well-Known Member
    NorCal/Ostate
    06 TRD offroad, 11 FJC
    kinda getting out of hand...
    I installed a new head unit years back along with new speakers and even built a custom sub box for the back. For whatever reason I started thinking about how I left the stock wiring and am confused on what to do...it sounds great how it is but I feel like I'm robbing power from the 2 ways in the front doors by leaving the stock tweeters hooked up. I have been doing a lot of reading but with all the different answers I am more confused then before ha :confused:. I could take the door apart but all the wires are bundled up anyways and I'm sure someone knows for sure what's happening. Are the speakers I installed getting a straight full spectrum signal and I can/should just cut the tweeter out? Or do I need to find the wires coming from the deck and extend those directly to the 2 ways?
  2. Oct 15, 2013 at 4:39 AM
    ike3000
    ike3000 Well-Known Member
    Are the stock tweeters still playing music? If so, then technically it is "stealing" some power from your two-ways. The only way to tell if it's noticeable would be to disconnect them.
    Personally I would have disconnected them from the beginning, because chances are the tweeters in your 2 way have a much better sound.
  3. Oct 15, 2013 at 6:05 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    My guess would be you're not losing enough to matter. I had the installer hook up my door speakers and amp both with and without the tweets and I couldn't tell when he had the tweets on unless I leaned right next to it. If you're just using the head unit to power them then I wouldn't even bother.
  4. Oct 15, 2013 at 8:02 AM
    tacomaniacmatt
    NorCal/Ostate
    Thanks for the replies. Yes they are still playing when you listen close. Seems like not a lot though but ya I got some nice 6x9's up front so I'm sure they would be happy with even just 4 more watts or whatever the tweets are taking. And just to clarify, if I cut the tweeter off right up at its connection the speakers I put in are receiving a straight signal from the deck? I don't want a signal from the crappy stock crossover or something or not have it be getting all the highs.
  5. Oct 15, 2013 at 12:05 PM
    ABA180
    East Bridgewater MA
    Either that or just remove the wire from the tweeter, I believe it is a clip that goes onto the tweeter. No need to cut it if you may want to return to stock down the road.
  6. Oct 15, 2013 at 12:59 PM
    tacomaniacmatt
    NorCal/Ostate
    Thanks for the help. Wanted to double check before I take it off find out it wouldn't make crap difference. I disconnect it and let you know what happens. It might make a difference not having a separate high power amp compared to running the 20 or so watts out of the deck
