Cutting with the Porter Cable
Discussion in 'Detailing' started by ABA180, Jul 12, 2013.
  1. Jul 12, 2013 at 10:51 PM
    ABA180
    ABA180 [OP] It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Going to use my new PC and pads..my friend's car has some paint transfer from a car that bumped her. I got some of it off earlier with my Walmart buffer but it didn't have the balls to do the heavy stuff.
    I have 3M scratch remover..should that work or more? I figure start with that stuff..it's an older car so it doesn't have to be perfect, she'd just like it as good as can be for short $$.
    What speed should I start at of the 6 and should I crank it up if needed?
    I got the $60 pad kit at autogeek so I'll use the light cutting pad..would the heavy one be too aggressive if I have to? Like to not damage the paint that belongs on there.
    Thanks much..I did a quickie wax job with it just using what it came with but first time trying to do this kind of cleanup with it and don't want to mess up.
  2. Jul 13, 2013 at 4:09 AM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    I would start with the med pad, and use a cutting compound such as meguiars m105 not scratch remover, You should be able to find it at the auto part store... Start slow speed to spread product then go to six.... If its a DA polisher let the product work a do six section passes on the area.....good luck ..
  3. Jul 13, 2013 at 1:54 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    If it's your first time dealing with this kind of thing start slow with the least gritty polish and slowly work your way up. Post a picture maybe too.
  4. Jul 13, 2013 at 2:59 PM
    ABA180
    East Bridgewater MA
    I used the 3M with my POS buffer prior and was able to remove half of it...it was about 2 ft long prior and got more stubborn as I approached the point of impact, which is what leads me to think it was a case of not having the right tools for the job mainly.
  5. Jul 14, 2013 at 1:50 AM
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    If it was just paint transfer then it should off fairly easily same with light scratches. If you take your fingernail and it catches on the scratch it usually will not come out.
    As you work periodically check if your getting the paint warm with your hand. If not up the speed a bit or put on a bit more pressure. The heat is what does a lot of the work when doing paint correction.
    Out of curiosity http://3mcollision.com/products/buf...-polishes/3m-perfect-it-rubbing-compound.html Is this the polish your using?
  6. Jul 14, 2013 at 6:50 PM
    ABA180
    East Bridgewater MA
    This stuff here: Scratches I'm not concerned with, merely removing the transfer..this is what I got about half of it off with before..
  7. Jul 14, 2013 at 11:30 PM
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    If it's really not coming off you could always just use some gun wash. Gets paint transfer off incredibly easily.
  8. Jul 14, 2013 at 11:37 PM
    ABA180
    East Bridgewater MA
    Sweet..any example you can link?
