Cv angle ok?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Aug 29, 2020.
  1. Aug 30, 2020 at 8:25 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Or add manually locking front hubs so the CVs aren't turned by the wheels unless hubs are locked.
    Saves the CVs for off roading in 4wd.
    Some people don't understand that the CVs are always spinning in both 2 and 4 wd mode.
  2. Aug 30, 2020 at 12:31 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Not the greatest pic of CV angles here, but mine has a diff drop and ~1" lift, maybe 1.5". Yours don't seem too bad.
  3. Aug 30, 2020 at 12:32 PM
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    You really don’t need a diff drop apparently till your at 3inchs but yea yours look similar to mine lol. Only time will tell i guess
  4. Aug 30, 2020 at 12:35 PM
    jbrandt
    Justin
    That's not exactly true.
    If you go over 3" you need a drop bracket style lift. A diff drop isn't likely to help beyond 3", and there are other control arm geometry issues above 3".
    2-2.5" is where you should be looking at a diff drop.
    I have extended travel coilovers, so I dropped the diff to account for the extra travel at full droop.
  5. Aug 30, 2020 at 12:37 PM
    Tacoscar-the-grouch
    Tacoscar-the-grouch Well-Known Member
    Josh
    North Idaho
    2001 Reg. Cab Tacoma
    OME kit 4.56's 235/85/16
    Your axle shaft (at least on one side) are blue, OP. Iirc, this suggests you have manual hubs. If this is true, the only time your CV's spin is when your hubs are locked. In this case, your CV angle can be more extreme, as you're not wearing your boots constantly and not going to rip them.
    Others have good advice - keep an eye on them for tears, and watch out for vibrations from the driver needle bearing going out.
  6. Aug 30, 2020 at 12:41 PM
    Allex95
    allex
    Yes I have manual hubs and yes they shouldn’t wear at all really cause not in 4x4. But I’m just wanting to make sure the angles are not drastic so when I go out it not more likely to fail
    jbrandt likes this.
  7. Aug 30, 2020 at 12:42 PM
    jbrandt
    Justin
    Good catch on the locking hubs, I skipped right over that.
    As far as wear and tear on them when you're not wheeling, sure. But a high angle will still bind and is more prone to break, so it's still a good idea to keep those angles in check.
  8. Aug 30, 2020 at 12:49 PM
    Tacoscar-the-grouch
    Josh
    North Idaho
    True, high angle is bad when in use. I have seen worse, but they are steeper than my own. I'd put in a diff drop OP, it is cheap and really easy.
  9. Aug 30, 2020 at 1:05 PM
    jbrandt
    Justin
    Yeah, I'm definitely a fan of diff drops.
    A lot of people poo-poo them because they don't set the CV angle back to "stock". But for $30 and a 20 minute installation, "better than it was before" seems like a no brainer.
  10. Aug 30, 2020 at 3:46 PM
    Allex95
    allex
    From what I’m told stock height is 21.5 and I’m at 24 so that’s a 2.5inch lift it looks like. Does that look like a 2.5inch lift?
  11. Aug 30, 2020 at 3:50 PM
    Tacoscar-the-grouch
    Josh
    North Idaho
    Stock height will be different for different trucks because of tire size. FYI. Best way to know your lift is before and after measurement at install.
  12. Aug 30, 2020 at 3:51 PM
    Tacoscar-the-grouch
    Josh
    North Idaho
    That said, from your CV angles, I’d say 2-2.5” is a good guess
  13. Aug 30, 2020 at 3:51 PM
    Allex95
    allex
    Yea I think so too. Should I do a diff drop or just drop the lift a little
  14. Aug 30, 2020 at 4:00 PM
    Tacoscar-the-grouch
    Josh
    North Idaho
    Your call. Diff drop is easy and cheap. Check the angles after install.
    Or, if it’s too tall for your liking right now, drop the lift. You have adjustable coil overs so should be easy as well
  15. Aug 30, 2020 at 4:03 PM
    #35
    Allex95
    allex
    Would you say it’s to high of a angle right now for liking.
  16. Aug 30, 2020 at 4:14 PM
    #36
    Kwikvette
    Fresno County
    4 run, 2 don't
    You're asking the same question over and over :rofl:
    Leave it alone or just do a diff drop; cheap, quick, and simple
  17. Aug 30, 2020 at 4:15 PM
    #37
    Allex95
    allex
    Yea ik:rolleyes:
  18. Aug 30, 2020 at 4:25 PM
    #38
    jbrandt
    Justin
    height of what? I must have missed what you're measuring.
  19. Aug 30, 2020 at 4:26 PM
    #39
    Allex95
    allex
    I talked to toytec and they said stock height is 21.5inches so when measuring from center of wheel to fenders I got 24inches so 2.5inch it seems is what I have. I think I might lower it to 2 because I want more down travel and my boots are slightly rubbing
  20. Aug 30, 2020 at 4:46 PM
    #40
    jbrandt
    Justin
    I just went out at measured mine and I'm at like 23" and by my estimates I have a 1-1.5" lift. But as others have said, that's not a super reliable measurement. There are a lot of variables; age, weight, etc...
    I wouldn't worry too much about what exact height lift you have - it doesn't really matter. The have adjustable coilovers, so you can make minor adjustments to make it level or whatever.
    As we've said before, your CV angles aren't really that extreme. But if it makes you feel better, throw a diff drop on it and don't think about it again.
