CV Angle?
Discussion in 'Suspension' started by dtrujillo63, Dec 10, 2008.
  1. Dec 10, 2008 at 10:43 PM
    dtrujillo63
    dtrujillo63 [OP] Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    Here is a shot of my CV joint angle. Is it angled too much? Should I lower my coilovers a bit or do you think they will settle some what?
  2. Dec 10, 2008 at 10:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have seen worse:D. what do you have the coilovers set at now??
  3. Dec 10, 2008 at 10:50 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'm not the greatest with my Taco but where exactly in that picture is the cv joint? Also, when I install my toytec diff drop in a couple of days, will it mess with my alignment or anything?:confused:
  4. Dec 10, 2008 at 10:51 PM
    dtrujillo63
    Denny
    Los Angeles
    I didn't measure my stock height but with 265/75/16 tires my fenders sit @ 39"s. I just installed them this weekend, do you think they will settle a bit?
  5. Dec 10, 2008 at 10:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    look right to the left of the tire.....the black boot there.......thats the cv. and installing the diff drop shouldnt do anything to your alignment.
  6. Dec 10, 2008 at 10:52 PM
    dtrujillo63
    Denny
    Los Angeles
    The CV shaft is the bar with the green sticker on it. A diff drop wont mess with your alignment.
  7. Dec 10, 2008 at 10:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, im pretty sure they will settle some dude. if you dont hear any clicking and popping, i dont think you got anything to worry about for a good while.
  8. Dec 10, 2008 at 10:54 PM
    dtrujillo63
    Denny
    Los Angeles
    Sounds good :D! I'll measure again in about 2 weeks and see if my height drops.
  9. Dec 10, 2008 at 10:55 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    you should wait a week or two to see how much the springs settle, then go from there if any adjustments are needed.
  10. Dec 10, 2008 at 10:57 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay got yah. Now how is it supposed to look? Level and straight?
  11. Dec 10, 2008 at 11:01 PM
    MonkeyProof
    SoCal- SGV
    generally speaking the rule of thumb is you don't want the ribs of the CV boots touching each other.
  12. Dec 10, 2008 at 11:02 PM
    dtrujillo63
    Denny
    Los Angeles
    Thats the plan!
    I'm not too sure... I doubt they sit leveled @ stock height, just not as angled.
  13. Dec 10, 2008 at 11:05 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay. I got my truck lifted on Monday so when I get my diff drop kit here by this weekend hopefully, should I just install them?
  14. Dec 10, 2008 at 11:10 PM
    dtrujillo63
    Denny
    Los Angeles
    Yes you should, its an easy install.
  15. Dec 10, 2008 at 11:13 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    So I assume you don't have a diff drop on yours?
  16. Dec 10, 2008 at 11:20 PM
    dtrujillo63
    Denny
    Los Angeles
    I got one, it was the first thing I installed when I originally only had 5100s.
  17. Dec 11, 2008 at 4:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    To me, it looks like your fins are touching. If this is the case, lower it a bit. If the fins are rubbing each other, they are gonna wear down eventually leading to a split in them dumping all the grease out. If they are touching when sittin still, they are gonna be much worse when traveling over bumps.
  18. Dec 11, 2008 at 10:32 AM
    dtrujillo63
    Denny
    Los Angeles
    Should I wait a bit and see if my coilovers settle a bit?
  19. Dec 11, 2008 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont know. They dont usually last that long when the boots are rubbing like that. If it were me, I would lower it a little, until the fins arent touching. If the springs sag, then you can raise them back up.
  20. Dec 11, 2008 at 3:41 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    +1. Kindof a pain, but I agree with Chris. You don't want to be driving down the road and blow that thing. Because it will happen at the wrong time!
