CV Axel Squeal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymac10, Nov 6, 2021.
  1. Nov 6, 2021 at 3:23 PM
    jaymac10
    jaymac10 [OP] Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Update: It was the inside brake pad that has worn down to the squeaker that was making the sound...
    2013 with 121,000 Klm. Sorry for the poor audio, but you can hear a higher pitch squeal like a metal angle grinder sound.
    Inside brake rotor looks clean.... dust shield doesn't seem to be bent...
    There is def a bit more friction vs the passenger side.
    Bumps don't seem to affect it.
    Any thoughts are much appreciated.
    Thanks,
    Jay
  2. Nov 6, 2021 at 10:23 PM
    Eastkat808
    Eastkat808 Well-Known Member
    Esket
    2012 DCLB 4x4 sr5
    bilstein 5100 cranked up
    Wheel bearing no?
    SR-71A likes this.
  3. Nov 7, 2021 at 3:03 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Another area is brakes - if worn is one of the squealers (metal tab that contacts rotor) starting to hit?
    Doubt CVs unless a boot is broken and grease all over so water got in. At 180k miles (290k km) mine are still OK.
    Wheel bearing/hub possible and search on how to determine as many posts.
  4. Nov 7, 2021 at 9:28 AM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks guys, breaks are new so don't think it's that. Will research bearings.
    Cheers,
    Jay
  5. Nov 7, 2021 at 11:36 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That doesn't sound like a wheel bearing, bearings growl and rumble and you can hear it inside the cab easily
    Check the backing plate, it might be rubbing against the rotor
  6. Nov 7, 2021 at 11:47 AM
    Eastkat808
    Esket
    2012 DCLB 4x4 sr5
    If the brakes are new, and it’s not a wheel bearing then check if the dust shield is rubbing on the rotor, just bend it back with your hands
  7. Nov 11, 2021 at 11:09 AM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    New video...
  8. Nov 11, 2021 at 11:44 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Oh god thats horrible with headphones on. Sounds like the brake squealer to me. Metal on metal
  9. Nov 11, 2021 at 12:18 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I might try taking off brake caliper to eliminate that. But brakes pads have lots of life still...
  10. Nov 11, 2021 at 12:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Have you looked at the dust shield yet? Try pulling it back away from the rotor
  11. Nov 11, 2021 at 12:43 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Just took caliper off and it's the inside pad that's worn to the brake squealer.
    Now just need to figure out how to separate the pads enough to get back on... Faxk.
  12. Nov 11, 2021 at 12:54 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The caliper pistons have to be pushed back in their bores to accept new thick pads
    With the caliper installed you can put 2 prybars or large flat screwdrivers between the pad and rotor and push the pistons back in the calipers.
    with the caliper off the truck you need a pad spreading tool or some big adjustable pliers like a plumber would use.. or a c-clamp
    If one pad is thick and one pad is thin then the pistons are probably stuck/seized. Might need a reman or new caliper
  13. Nov 11, 2021 at 12:56 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Take caliper off. Place brake pad onto piston and use a c clamp to push piston back into caliper
  14. Nov 11, 2021 at 1:25 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks guys, got it all put back together. Just pissed that I need new brakes already.
  15. Nov 11, 2021 at 1:26 PM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Did you install new brakes or did a shop do it?
  16. Nov 11, 2021 at 1:30 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    A shop did it. I'll call them tomorrow and find out how many KLMs ago I had them done.
  17. Nov 11, 2021 at 1:37 PM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    I would. Might be some splanin that needs to be done. If the work was legit...might need to look at your driving style and take it easy on those brakes.
    SR-71A likes this.
  18. Nov 11, 2021 at 5:01 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Got new brakes done in July 2018. So I probably have under 35,000klm on the new ones....
  19. Nov 11, 2021 at 5:21 PM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Yea should get more life out of them i would think.
  20. Nov 11, 2021 at 5:23 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Was the pad wear on inner vs. outer consistent? Since the Tacoma has fixed calipers, the pistons push from both sides and if all four are working the same the pads should wear evenly. If not, the caliper likely has an issue.
    SR-71A and b_r_o like this.
