CV Axels...quick question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SJginger, Jan 15, 2012.
  1. Jan 15, 2012 at 10:17 AM
    SJginger
    SJginger [OP] Well-Known Member
    Jerry
    South Jersey
    08 tacoma trd sport, stock for right now!!!
    I have reserached this question and found no deffinet answer.
    I have to replace driver side CV AXEL...can I get away with just replaceing one or replace both driver and passenger cv's so they wear evenly?
  2. Jan 15, 2012 at 10:19 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    you can just replace one and be fine.
  3. Jan 15, 2012 at 10:22 AM
    SJginger
    Jerry
    South Jersey
    Ok cool thanks....cuz I know with wheel bearings u should replace both didn't know if cv's were the same
  4. Jan 15, 2012 at 10:24 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Never heard that about wheel bearings.
    but yeah you'll be fine, I replaced my drivers side only about a month ago and know many others have done the same.
  5. Jan 15, 2012 at 10:31 AM
    SJginger
    Jerry
    South Jersey
    Thanks....the only reason I say that about bearings is if one goes bad and u replace them with new ones it might cause the other side to fail since u got new on one side and wore down ones on the other....if that makes any sense at all...Haha
  6. Jan 15, 2012 at 10:34 AM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Confirmed. Just replaced only drivers side on buddies civic.
  7. Jan 16, 2012 at 4:51 PM
    SJginger
    Jerry
    South Jersey
    How do u tell if ur cv joint is bad...I just did wheel bearings 2 months ago. Just got my lift installed 3 days ago and noticed fluid leaking from where the cv goes into the front diff. I also have a bad vib from 30-35mph and 40-45mph and when the steering wheel is turn all the way to the drivers side I get a pop and a clunk noise.
    Before I installed the 1" diff drop no fluid everything was after install all the problems so I un-installed the diff drop. Any help or input would help thanks
  8. Jan 16, 2012 at 8:26 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    probably the axle seal in the diff. you'll have to pull the CV out to replace it.
    not sure about the vibes. your CV is bad if the rubber boots are ripped
