CV Axle Brands
Discussion in '1st Gen. Tacomas (1995-2004)' started by DustStorm4x4, Jan 4, 2017.
  1. Jan 4, 2017 at 4:40 AM
    DustStorm4x4
    DustStorm4x4 [OP] BBC 2020
    U S A
    04 Jeep LJ
    Help me out a little with which CV axles to get. My 4wd isn't working and there's some play in the CVs so I'm thinking about swapping them out.
    I read some posts that OEM is best, and then some say CVJ is best, NAPA brand is good, etc. Which one should I get???
    I appreciate any and all answers in advance.
  2. Jan 4, 2017 at 4:46 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I just went with Napa for now. Just replaced them because I blew a boot. Keeping my oem's for spares. As long as your not going heavy off roading they should last you a good while
    DustStorm4x4[OP] and Coot83 like this.
  3. Jan 4, 2017 at 4:47 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    From what I hear, going with OEM is the route to go. CVJ is pretty good as they have some quality rebuilds, especially if you want modified axles. I got some used OEM CVs from a pick and pull shop from CA on ebay...about $100 per cv.
    Coot
    DustStorm4x4[OP] likes this.
  4. Jan 4, 2017 at 4:48 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I second this, if you don't plan to really see dirt then try out Napa. From what I hear with those, either they will leak upon install or wont. If they don't leak at all in the install then you should be good!
    Coot
  5. Jan 4, 2017 at 4:50 AM
    QMEDJoe
    Joe
    Ive had my Napa's on for about two months. Drove from DFW to N'awlins then to Asheville and back to Dallas and no problems
  6. Jan 4, 2017 at 4:51 AM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    CVJs are re-manufactured OEM CVs. You have to send your CVs back to them or get hit with a $190 core charge. I just replaced mine with CVJs, but you have to factor in shipping CVs both ways. So add another $100 in shipping. The quality of the CVJs was great, they didn't look like they were ever used.
  7. Jan 4, 2017 at 5:35 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I think I'd rather have a rebuilt OEM CV axle over an aftermarket. Aftermarket should work okay for a pavement pounder, if you off road, the strength and design of the OEM joint is much better.
  8. Jan 4, 2017 at 10:18 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I plan on actually using 4wd off-road. Should I forget about NAPA brand or should I give them a try anyways?
  9. Jan 4, 2017 at 10:19 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Depends. If you've got the coin, get CVJ. If you have the time to screw with redoing the boots all the time, get OEM. If you just want to be able to pop and swap a CV if it breaks or tears, get a Napa lifetime.
    I used to reboot my OEM axles. I've got the diff drop and did the BSM... still ended up in tears, just closer to the middle of the shaft instead of where the fins usually rub. So I decided just to get NAPA stuff now. It only takes me about 30-45 minutes to swap a CV, and I frankly would not have to worry if I drive on a lifetime unit with a torn boot for a while. Hell I knew people who would drive and wheel on a torn boot CV for a considerable amount of time and never had problems as a result.
    If you do plan to get a Napa unit, I would honestly recommend picking up a spare if possible, especially if you do hardcore wheeling. Though I've read around and people either have bad luck with breaking them or they don't. But that's usually with the guys that beat on their shit.
    Calion and DustStorm4x4[OP] like this.
  10. Jan 4, 2017 at 10:52 AM
    cruiserguy
    Elijah
    SEKS
    This is good advice. If you go Napa, have your OEM rebuilt and keep as spare or install it and keep Napa as spare. When I wheeled more I always kept a spare axle after I broke a front axle on my 80 series cruiser in Moab. Slickrock turns SLICK when wet. Great traction dry though. Anyways, never bad idea to have a spare if you wheel.
  11. Jan 4, 2017 at 10:57 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Good call on the spare man, I think if you are gonna wheel any sort of rock stuff never hurts to have one.
    Coot
  12. Jan 4, 2017 at 11:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Like it was said It all comes down to your use .
    My truck hauls and pulls stuff .
    Off Roading days are over Getting out of my Driveway is enough of an Adventure unless I get talked into going to rescue someone,
    I want with the New Napa Ones in my Truck and the 4Runner so far so good been a few years
    The joints were fine it was just the boots dry rotting I have the Boot Kits just never took the time.
  13. Jan 4, 2017 at 12:52 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    My pickup is lifted. I used a drop diff kit and adjusted the coils to about 2" in the front. I have NAPA chassis CV axles in there. Boots have been great for a long time with no rips or tears and seem to hold up quite well.
