CV axle compatibility?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaTRD4x402, May 26, 2014.
  1. May 26, 2014 at 10:20 AM
    TacomaTRD4x402
    TacomaTRD4x402 [OP] Well-Known Member
    So Cal
    '02 Tacoma TRD 4WD 3.4 5spd S/C Long Travel
    Can I get someone here to confirm that an OEM CV axle off a '99 4wd TRD taco will fit perfect on an '02 4wd TRD taco?
    I checked a few parts websites and seems like part #'s match up but that's for aftermarkets n reman's, would that really make a difference? :confused:
  2. May 26, 2014 at 11:23 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Do either trucks have push button 4x4 or locking hubs?
  3. May 26, 2014 at 12:25 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    First gens all use the same CVs. The only difference is "ADD" or "Man Hub". ABS has absolutely nothing to do with it.
  4. May 26, 2014 at 4:03 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    x2
