CV-Axle dust seal part number
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rockbaron1, Mar 13, 2024.
  1. Mar 13, 2024 at 3:06 PM
    Rockbaron1
    Rockbaron1 [OP] Well-Known Member
    Pat
    03 Tacoma
    everything
    So im pretty sure the the Toyota part number is 90304-A0001. What im really interested in is an aftermarket version, something I can order from Amazon or rock auto. Ive been looking at pictures of seals for about an hour now I cannot figure out which one is for the cv axle and which is for the back side of the wheel hub. None look exactly like what im seeing on my axle.
  2. Mar 14, 2024 at 9:51 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    First thing it looks like you have a 1st gen but posted in the 2nd gen section. May want to have the thread moved over there:
    https://www.tacomaworld.com/forums/1st-gen-tacomas-1995-2004.4/
    Second, I strongly suggest to get the OEM seal. Better quality, will possibly outlast doing an aftermarket seal twice over. They don't cost much and you can order them online from many sources.
  3. Mar 14, 2024 at 6:21 PM
    Rockbaron1
    Pat
    03 Tacoma
    everything
    I have many Toyota’s, this is about a 2nd gen Tacoma. I’m aware of the difference in quality but I don’t see a reason to spend $45 on a $10 seal in this particular instance. Besides rockauto is fast, My local Toyota dealer sucks, and I’m a bit pressed for time. I ended up just ordering both inner and outer wheel seals from rock auto and they should be here on Monday. I can regear the rear diff while I wait for the parts to finish up the front.
  4. Mar 14, 2024 at 6:37 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    90304-A0001 is the correct P/N for the dust seal on birfield CV joint. No aftermarket P/N available last I checked. I did some searching in 2022 when my RCV axles came in missing those dust seals.
    The one that goes on the inboard side of the knuckle has several aftermarket P/Ns. I used National 710573. Also available under Timken branding. (Figure a seal from a bearing manufacturer is reliable enough.) https://www.rockauto.com/en/moreinfo.php?pk=1927206&cc=0&pt=1860&jsn=1
    The "outer" seal on Rock Auto is the one between the hub and the wheel bearing. This one is usually included if you buy a hub-bearing assy with the captive bolts, etc. https://www.rockauto.com/en/moreinfo.php?pk=1146628&cc=3354143&pt=1860&jsn=433&optionchoice=0-0-1-1
  5. Mar 14, 2024 at 6:54 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Wrong part number for a second generation seal. I have it at home and can post if you still need the part number.
  6. Apr 23, 2024 at 4:03 PM
    rockandstone
    rockandstone New Member
    2010 TRD Manual 4x4
    @zippsub9 do you by chance have that seal part number handy for a 4wd 2nd gen?
    zippsub9 likes this.
  7. Apr 23, 2024 at 5:28 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Forgot to post this earlier.
    90304-A0001
