CV Axle for manual hubs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deathbysnusnu, Dec 11, 2013.
  1. Dec 11, 2013 at 1:37 PM
    Deathbysnusnu
    Deathbysnusnu [OP] Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I have grease showing around the boots where the smaller clamp is. Original shafts so I expected it with the weather cracked boots. I pulled the old clamps off, they were loose, and replaced with regular hose clamps as a band aid for now.
    No ADD, I have manual hubs.
    Looking at Napa, I find a few types with a description.
    "IMPORTANT INFO: w/o Automatic Disconnecting Differential,w/ Outboard Circlip End"
    Is this the right part?
    http://www.napaonline.com/Catalog/C...ft-Right-Front-Remfd/_/R-NMD954169_0271586724
    Also, They show a left and a right. Does it matter?
  2. Dec 11, 2013 at 1:47 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    thats the right part
  3. Dec 11, 2013 at 1:50 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    If the clamp on the boot stopped it from leaking grease out the cv then call it a day :)
  4. Dec 11, 2013 at 2:06 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thank you.
    That's what I'm hoping for. Just want to make it through the winter.
  5. Dec 11, 2013 at 2:21 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    If they are OEM and your fix does not work I would re-boot them. You can get re-boot kits from Toyota that come with everything you need. The OEM ones are probably stronger than anything aftermarket.
  6. Dec 11, 2013 at 2:26 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I had not thought of this. Thanks for the tip, I'll check into it.
  7. Dec 11, 2013 at 2:55 PM
    bellassaiw10
    Currituck NC
    I tried it ... Too much work honestly get lifetime advance auto replacements, nothing beats free replacements and honestly I broke more ome then I have these
  8. Dec 11, 2013 at 3:54 PM
    xcmtb83
    Iowa
    It really depends on how many CVs he plans on breaking in the future. If he knows he will be going through a lot then the lifetime replacements would make sense. I personally didn't find the reboot too much work and cheaper than two new CVs.
