CV axle HELP?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cupcake, Mar 7, 2014.
  1. Mar 7, 2014 at 7:46 PM
    Cupcake
    Cupcake [OP] Member
    Washington
    01 Tacoma TRD
    Suspension and body lift, wheels, tires, Jet fuel module
    This just happened, should I replace the entire CV axle or just the boots? Both are torn... /:
  2. Mar 7, 2014 at 7:50 PM
    02goldie
    02goldie Well-Known Member
    Brock
    Lenoir, NC
    2016 Sport DCSB 4x4
    OME lift, spidertrax, 285 duratracs
    when mine ripped i replaced the cv axle. also installed a diff drop and haven't had an issue since
  3. Mar 7, 2014 at 7:51 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Replace the entire CV ....
  4. Mar 7, 2014 at 8:16 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Easier to replace the entire thing and you could get a lifetime warranty on them
  5. Mar 7, 2014 at 9:01 PM
    Cupcake
    Cupcake [OP] Member
    Washington
    01 Tacoma TRD
    Ok, I figured but wasn't sure. Thanks for the opinions, helps me a ton! My ex husband usually decided and helped with replacing things that needed it, you guys are making being single easier! Haha much appreciated!
