CV axle help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bradyknight14, Oct 24, 2021.
  1. Oct 24, 2021 at 11:33 AM
    Bradyknight14
    Bradyknight14 [OP] Member
    Brady
    2008 DCSB Trd sport
    Hello,
    I just changed my passenger side CV yesterday(2008). Install went smoothly and it is all put back together. However, i am now questioning if the cv is fully seated. It seems to be all the way in but if i pull on it, it slides out quite easily. Did i put too much grease on the end? Is it not properly seated? I don't want to have to tear apart the front end again.
  2. Oct 24, 2021 at 11:36 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    did you remember that circlip at the end? if it went in very easy without fighting, then you might have forgotten that. You will need to pull the CV and add that back before putting together
    Bradyknight14[OP] likes this.
  3. Oct 24, 2021 at 11:39 AM
    Bradyknight14
    Brady
    2008 DCSB Trd sport
    The circlip was definitely on. It definitely went in without to0 much of a fight though. I put a fair amount of grease around the circlip.
  4. Oct 24, 2021 at 11:41 AM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    The shaft slides easily (that's how it doesn't bind when the suspension compresses). If the end that seats into the differential isn't seated, it will leak gear oil.
  5. Oct 24, 2021 at 12:28 PM
    Bradyknight14
    Brady
    2008 DCSB Trd sport
    When its pushed all the way in it doesn't leak. however, I can pull it out far enough by hand that it does leak.
  6. Oct 24, 2021 at 12:47 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    This might be a stupid question but when you are pulling on the axle is the knuckle installed/cv axle nut tight?
  7. Oct 24, 2021 at 12:51 PM
    Bradyknight14
    Brady
    2008 DCSB Trd sport
    yes, the knuckle is installed and the axle nut is tight. The tire and everything is back on the truck. It just seems like there is much more play than there should be.
  8. Oct 24, 2021 at 12:53 PM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    Crazy, it's like the clip is too weak to hold the cv shaft in the housing.
  9. Oct 24, 2021 at 12:56 PM
    joeyv141
    New Jersey
    I hate to say it but I would agree that you should remove the axle and make sure the clip is present/not damaged. I just removed both axles yesterday and the pass side was a bitch to get out with that clip.
  10. Oct 24, 2021 at 1:15 PM
    joeyv141
    New Jersey
    Wait a minute, you said you changed the axle, any chance you went from OEM to cheep cheep aftermarket maybe with the wrong clip? You could probably put the previous axle clip on the new axle.
  11. Oct 24, 2021 at 1:28 PM
    Bradyknight14
    Brady
    2008 DCSB Trd sport
    yes they are aftermarket CV's from NAPA. looks like im going to have to pull it again and put the old circlip on the new axle.
    gunn_runner likes this.
  12. Oct 24, 2021 at 2:13 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Did it 'snap' into place when you inserted it? If you have a long bar or punch, try smacking it into the diff a little more. You should here it kind of snap/seat into place. You might be able to do this without taking everything back apart.
  13. Oct 24, 2021 at 2:49 PM
    Bradyknight14
    Brady
    2008 DCSB Trd sport
    I do remember it snapping into place. image 1 shows where it is currently sitting. Image 2 shows how far back I can pull to where it starts to drip oil. image 3 shows where i cant pull back any further and it feels like the circlip is catching somewhere.
  14. Oct 24, 2021 at 3:13 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Nice pictures. But that does not look right. Pull apart for safety’s sake. NAPA are usually good products. Check part numbers make sure they are the right part also. Could also be wrong part packed in wrong box.
    Goldwrench likes this.
  15. Oct 24, 2021 at 3:56 PM
    joeyv141
    New Jersey
    Yeah that's definitely not right. Could it be the wrong side axle. My OEM axles the driver side diff splines part is smooth but the pass side diff splines part has groves/notched in it to allow a slide hammer to be used for removal.
    I can take pictures tomorrow at work if you want.
  16. Oct 24, 2021 at 4:13 PM
    Bradyknight14
    Brady
    2008 DCSB Trd sport
    This is the axle I replaced my old one with. I layed them side by side and they were definitely the same part. I didn't know they could be driver/passenger side specific though. It could be that.
  17. Oct 24, 2021 at 5:08 PM
    winkel
    Corydon, IN
    Yeah, that's definitely seated, or in far enough. BUT, it shouldn't be easy to pull out.
    Something isn't right. Even if the driver/passenger side were the same length, which I don't believe they are, the shafts on the end should be the same.
    You'll need to pull that back out and compare to the unit you replaced and check the clip.
  18. Oct 24, 2021 at 5:09 PM
    joeyv141
    New Jersey
    I could easily be 100% wrong it was just a though. See if napa/toyota/whoever has different part numbers for left and right
  19. Oct 24, 2021 at 5:28 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    They're not side specific.
  20. Oct 24, 2021 at 5:39 PM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Same CV for both sides. I’m guessing the clip isn’t on there or isn’t doing it’s job. It will have a little play but not nearly that much. First picture looks fully in. I’d tear it down and hope you find the clip, but I guess you’d know pretty quick if it had dropped in the diff…may want to top off your diff fluid if you’ve been driving around like that.
