CV axle install, won't rotate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rat_Bastard, Jul 16, 2021.
  1. Jul 16, 2021 at 7:49 PM
    Rat_Bastard
    Rat_Bastard [OP] Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    I'm installing the driver side cv. I believe I have the splines seated but once the cv is inserted about a half inch, I'm not able to rotate it. I've installed CVs a handful of times with never having this issue. When removing the broken CV, I was able to rotate it. The new cv is a rebuilt OEM from the delaer. Any tips would be appreciated.
  2. Jul 16, 2021 at 7:52 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    are you saying that the axle will not spin when engaged with the differential splines? 1/2" doesn't seem like full engagement with the front differential but I do not know how much spline interface is typical for this application. is the CV joint housing close to the diff housing when it's as far in as it will go? pictures?
  3. Jul 16, 2021 at 7:56 PM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Correct.
  4. Jul 16, 2021 at 7:56 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Is the transfer case in 2WD?
  5. Jul 16, 2021 at 7:59 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try putting the broken cv back in and see if it spins
  6. Jul 16, 2021 at 8:11 PM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    this is the second attempt with the new one. When the axle is just getting seated, it rotates fine...but once pounded in another quarter inch is when it seizes...I am afraid to keep pounding it at this point , but it might just be a spot where the c clip is seizing the axle.
  7. Jul 16, 2021 at 8:19 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Is the truck in 4Hi?
  8. Jul 16, 2021 at 8:50 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Not sure i follow exactly the conditions you are saying, but check your C clip is not galled or bent. What i recall was fairly light force until it got to compressing the C clip then a good tap with a hammer and kid size crow bar in the notch got it. Are you saying the metal flange on the CV is touching the diff where it seals?
    Double check you got anything out of the diff that you stuffed in to keep oil from dripping out.
    Maybe stupid question but the other end of the CV is not already in the wheel front axel hub right?
    parel likes this.
  9. Jul 16, 2021 at 9:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    First look and see if the new CV has any mark is made by pounding it in?
    And also see if the diameters are the same on old and new.
    I don’t like pounding the CV in.
    Put the CV in and push it in until it stops.
    Then pull it 3/4 of the way out, then SHOVE it in fast.
    It usually goes in a lot easier this way.
  10. Jul 16, 2021 at 9:06 PM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Problem resolved. Thanks for your feedback!
    TnShooter likes this.
  11. Jul 16, 2021 at 9:07 PM
    TnShooter
    Deogee
    STOCK
    Awesome, good to hear:thumbsup:
  12. Jul 16, 2021 at 9:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What did you find
    Skydvrr and Bertw192 like this.
  13. Jul 16, 2021 at 9:25 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    What ended up working for you?
    Skydvrr likes this.
  14. Jul 17, 2021 at 5:16 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    :annoyed::bananadead:
    jmneill, Skydvrr and 9th like this.
  15. Jul 17, 2021 at 5:25 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    C'mon man!
    Skydvrr likes this.
  16. Jul 17, 2021 at 8:11 AM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    What a tease :rofl:
  17. Jul 17, 2021 at 8:31 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Pretty sure this was it.
    Gutentight[QUOTED] likes this.
  18. Jul 17, 2021 at 8:33 AM
    dagobert
    dagobert Well-Known Member
    Probably something simple and is embareassed about it......we've all been there.
    Note: Rebuilt and remanufactured - big difference between the 2. Make sure you are buying remanufactured.
  19. Jul 17, 2021 at 8:42 AM
    Gutentight
    IL
    About 15 min after I posted it was fixed..
    Unless OP wants to share I will say this is a good bet, but I might still go 50% odds forgot something in the diff used to block oil leak.
    Edit: naw won’t rotate, so I would give 10% odds jammed something in diff, 90% other end was in the front wheel axle hub.
  20. Jul 17, 2021 at 8:58 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    @Rat_Bastard , what was the fix? Which one of the tips you asked for, worked?
