CV Axle keeps breaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeronimo21, Feb 4, 2018.
  1. Feb 4, 2018 at 8:51 AM
    Pigpen
    Dan
    Northwest Montana
    And always have a spare on hand, apparently.
  2. Feb 4, 2018 at 8:52 AM
    Jeronimo21
    Jeronimo21 [OP] Member
    Johnathan
    2005 stealth Tacoma TRD Sport
    Lifted w/ mud tires
    Yea, I’m probably gonna have to wait. I’ve spent all my money on that one .
  3. Feb 4, 2018 at 10:20 AM
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
  4. Feb 4, 2018 at 10:37 AM
    lynyrd3
    Bill
    East Central Upstate NY
    :facepalm:
  5. Feb 4, 2018 at 10:42 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Is your truck an auto or manual? If it’s manual you could try putting it in first with the gas pedal floored then dump the clutch as fast as you can. That transfers more of the stress to the rear driveshaft which is bigger and stronger than the front cv shafts
    fatfurious2, TireFire, Texoma and 3 others like this.
  6. Feb 4, 2018 at 10:51 AM
    Jeronimo21
    Johnathan
    Lifted w/ mud tires
    It’s a automatic .
  7. Feb 4, 2018 at 10:53 AM
    lynyrd3
    Bill
    o_O. :rofl::rofl::rofl:
  8. Feb 4, 2018 at 11:00 AM
    joes06tacoma
    Joe
    Central Coast, CA
    2 things:
    1st- Anything will break when subjected with enough of a shock load. Spinning tires catching traction suddenly and snapping an axle is pretty old news when talking about cars/trucks.
    2nd- Lifted trucks with steep angles on CV axles can be more prone to breaking CVs due to binding of the CV joint. A friend was having similar problems when driving in the sand dunes. He finally figured out he was breaking the CVs when the truck started to bounce. He put limiting straps on his front suspension to keep the CVs from binding when the suspension dropped down too far. Problem solved in his case. He had a fullsize Chevy.
  9. Feb 5, 2018 at 11:33 AM
    Jeronimo21
    Johnathan
    Lifted w/ mud tires
    Update: the engine is dead and the truck is getting traded in for a RAM .
    gunn_runner likes this.
  10. Feb 5, 2018 at 11:36 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    6 Pages by this evening :D
  11. Feb 5, 2018 at 11:43 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Buy cheap parts get shitty results
    Jeronimo21[OP] likes this.
  12. Feb 5, 2018 at 11:58 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This explains everything that needs explaining.. Malfunction found..
  13. Feb 5, 2018 at 12:30 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    How in the heck did you manage to kill the engine..
  14. Feb 5, 2018 at 12:47 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm wondering the same thing. MAYBE he put in new, stronger CVs and he floored it in 4WD, but his engine couldn't handle the traction and just 'sploded
    Icepuck72, tcjacado, EDDO and 2 others like this.
  15. Feb 5, 2018 at 12:54 PM
    #35
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Good thing you can't break a RAM. Oh wait, ask two of my friends who have blown two 5.7L Hemi engines with less than 100k miles on them. Buy an extended warranty! :)
    MtnMan307 and lynyrd3 like this.
  16. Feb 5, 2018 at 12:56 PM
    #36
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    He had his foot hard down in neutral and threw it into drive while having it in 4lo
  17. Feb 5, 2018 at 12:59 PM
    #37
    eon_blue
    Azusa, CA
    Some people don't deserve nice things
    TireFire, cory02taco and stickyTaco like this.
  18. Feb 5, 2018 at 1:01 PM
    #38
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I'm using this for every diagnosis possible. Blinker not working, drop the clutch. Maint Rqd light on and what does it mean, drop the clutch.
  19. Feb 5, 2018 at 1:07 PM
    #39
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    probabaly hit a patch of ice then pavement and snapped it. mines done that
    :rofl: :rofl: then this?! I can't even at how quick this went to shits-ville. Please elaborate
    :worthless:
    lynyrd3 likes this.
  20. Feb 5, 2018 at 1:09 PM
    #40
    Bebop
    Nick
    This has to be a trolling effort.
    Nobody can be that dumb to think a Dodge Ram is superior to a Toyota...
    2015 TRD Sport and lynyrd3 like this.
