cv axle leaking. not from boot
Discussion in 'Suspension' started by rab89, Jul 4, 2011.
  1. Jul 4, 2011 at 10:40 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I'll get pics tomorrow, the just of it is, I recently had my ome 882's put on and new front diff fluid, now about 2 weeks later my cv axle is leaking oil from where the boot meets the axle shaft.
    Is this something I can fix without getting a new cv axle?
    just to be clear, this is not a torn boot.
  2. Jul 4, 2011 at 10:46 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Possibly. I used to put RTV sealer around the inside edge of the boots when replacing them on other vehicles. Sort of as insurance that they would only leak if the boot got torn. Although this would require removing the axle and re-clamping the boot. But still cheaper than a new axle.
  3. Jul 4, 2011 at 10:51 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I had the same thing happen and I had the clamp on the boot tightened. But that was just temperary...
  4. Jul 4, 2011 at 11:14 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    thats a good idea! then I can do the mod for saving the boots at the same time.
  5. Jul 10, 2011 at 9:36 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ok so I did some research today on the truck, i found for whatever reason the clip is just really loose, but a lot of grease has come out, so I'm going to have to re-grease it of course... what kinda of grease do I get? i was surprised at how thin the oil/ grease is that came out. it's not much thicker than engine oil, is that normal?
  6. Jul 10, 2011 at 9:45 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    I use worm drive or hose clamps. U have to find one that are narrow enough to fit in the boots grove. The ones sold home depot and such are too wide, I got mine at west marine.
  7. Jul 10, 2011 at 10:11 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    good idea, thanks!
    I should be able to check what kind of grease in my haynes manual.
  8. Jul 12, 2011 at 11:44 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    today i got new grease and clamps, I got the wheel and disc brake off, then the 4 bolts on the bottom of the lca? were too tight, so I put it back together... I am NOT motivated to work on my truck these days. ugh.
