CV Axle options
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coppertone, Mar 11, 2014.
  1. Apr 29, 2014 at 9:30 AM
    #41
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Its the inner only. I think they can also do outer though (recommend if you have the money). One note, when talking to them, they say the outer boots they use are not as good a quality as the OEM boots and can install OEM outer boots for extra $$$ as well. But like I said, I would see about some high angle outers if you can afford it.
  2. Apr 29, 2014 at 10:04 AM
    #42
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Does anyone have any experience with EMPI brand cv axles? Been thinking about those when I need to replace next time.
  3. Apr 29, 2014 at 10:16 AM
    #43
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Better off with reman OEM axles. It looks like EMPI only make boots and not axles. They are probably partnered with a cheap Chinese company to make the axle and they provide the boot and name.
  4. Apr 29, 2014 at 10:32 AM
    #44
    Trapperr
    Reno, NV
    Thank you for the heads up. Is cvj the only company that makes reman oem units?
  5. Apr 29, 2014 at 11:27 AM
    #45
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    That I know of :notsure:
    You can always do it yourself. Not hard but a bit time consuming and very messy.
  6. Apr 29, 2014 at 2:34 PM
    #46
    bpkrules
    bpkrules Well-Known Member
    Jon
    Houston
    Tacoma4x4 BATMAN
    ARB Front bumper. Custom rear bumper. ARB snorkel. 883s 90004s. 1 inch daystar body mounts lift. Full skids. Leather seats.
  7. Apr 29, 2014 at 3:08 PM
    #47
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    It has the potential to be but with careful planning and attention, isn't that bad. Last time I did it, didn't even wear gloves. Kept most of the grease in the boots when I took them off then cleaned out what I could with paper towels.
  8. May 19, 2014 at 9:58 AM
    #48
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    I called CVJ a few minutes ago and they said they couldn't do high angle boots on the outers. Something to do with the angle.
    I also asked one of their tech's named Sean about the 'boot slide mod' and he wasn't familiar with what I was talking about.
    Chris, do you remember the name of the individual you talked with about the slide mod?
  9. Jul 31, 2014 at 10:12 AM
    #49
    ChewbacaTW
    ChewbacaTW My progeny will be awesome!
    Sam
    Flagstaff, Arizona
    02 Xtra Cab TRD off road
    K&N air intake, custom exhaust, Powerslot Brakes, urethane steering rack bushings
    Has anyone had any experience with NAPA CV axles? I just replaced my passenger side axle with one and it worked great for about a mile, and then I started getting a scraping noise coming from that wheel. They seemed to be the same as the OEM axles to me. I can't tell if I screwed something up or if I got a bad rebuild or what.
  10. Jul 31, 2014 at 10:32 AM
    #50
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Just last week replaced a Napa axle that had been in a low duty Subaru legacy exactly 2 years. It was shot. Outer boot torn and inner Trap beaing gone/very gritty.
  11. Jul 31, 2014 at 12:00 PM
    #51
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I sent a letter with my axle and included the link to the 1st gen boot slide mod thread and a quick explanation of what it was. Its not a hard concept and Im sure a tech can figure it out.
    Weaker and (from what I hear) dont articulate as much as stock. Cheap for a trail spare and no questions warranty.
  12. Jul 31, 2014 at 1:38 PM
    #52
    ChewbacaTW
    Sam
    Flagstaff, Arizona
    Crap!!! I guess I'll have to take it off and put the old one back on for now till I can give CVJ a call and get some of those.
  13. Jul 31, 2014 at 1:46 PM
    #53
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
  14. Jul 31, 2014 at 1:54 PM
    #54
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    The lotus axles are really nice. The thing is they are too strong imo. I'd rather have the cv break than something inside the front diff.
  15. Jul 31, 2014 at 1:55 PM
    #55
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, Ive seen those. They replace the outer cage (typical point of failure) with a much stronger part. Its very nice but the price is kind of hard to justify. The issue I have with those are two fold:
    -For $1000 (one pair), I can buy ~15-20 pairs of napa axles.
    -If the outer cage doesn't break, what will? The 7.5" front diff isn't exactly the strongest. Ive read of two ppl claiming they blew their front diff running these axles (locked front). Its a bandaid; if you are wheeling hard enough that you need to drop $1k on CV axles, you should probably consider SAS :notsure:
  16. Jul 31, 2014 at 2:07 PM
    #56
    ChewbacaTW
    Sam
    Flagstaff, Arizona
    Totally agree. $1000 will put you well on your way to an SAS kit.
  17. Jul 31, 2014 at 4:15 PM
    #57
    Enigma8246
    Lee
    Central Arkansas
    Crap. My wife's Subaru has one in it now. No problems yet but this is definitely not what I wanted to hear.
    I went with CVJ. When I started doing the work I decided to go ahead and do the lower ball joints. Then I noticed the sway bar end links were shot and replaced them. Then I noticed the tie rod boots were torn and replaced them too. Then wound up having to swap the diff drivers side output bearing with a bushing from ECGS. Bottom line: between all of this and the Light Racing upper control arms, I probably could have just done a SAS.
  18. Jul 31, 2014 at 7:01 PM
    #58
    40950
    CR, WA
    stock
    Sorry folks, not trying to dis Napa stuff as I think it is better than most and I shop there quite often. Napa warranty's are some of the best in the biz.
    This previous owner had put the semi beat down on this 96 Subaru. Multiple Big hairy dogs roaming the cramped interior and he would waylay the sheetmetal when he was pissed. A $500 awd beater,,that still gets lots of miles per gallon. EAZY cv axle change on those. Done in a few moments and moved on to another project.
    No $1k axles needed here,,I'll pass on those. They look cool, someone spent some duckets getting it right so he's trying to recoup asap I would guess.
  19. Aug 1, 2014 at 4:12 PM
    #59
    ChewbacaTW
    Sam
    Flagstaff, Arizona
    So just in case anyone is interested... I Removed the NAPA part and put the old OEM one back in and the scraping noise went away. Durring my inspection when taking the NAPA one back off I noticed that there was an awful lot of brake pad dust built up around the edge of the outer pad. I thought about my experience installing it and I realized that it was really really tough getting the axle to seat in the hub assembly with the axle nut.
    I realized that it hadn't actually seated as deep as it needed to (about 1/4 inch too little) even though I torqued it to the proper spec (184 ft/lbs) and i was able to cotter pin it and everything. It was a total bitch to get seated even that far... In any case, I believe this was transferring pressure through the hub to the rotor and causing it to rub on the outer pad.
    I inspected the threads on both axles and noticed that the metal of the OEM one was a chomoly steel with no coating but the NAPA one seem like a high carbon steel with a coating on it... I'm assuming to make it corrosion resistant like the chomoly OEM one. I believe it was that coating that made it prohibitively difficult to get the axle to seat in the hub.
    Like i said, I put the OEM one back in and it was MUCH easier to install and I will be driving around on that till I can get my order from CVJ.
  20. Aug 1, 2014 at 4:36 PM
    #60
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Careful with the boot slide mod on the outer on a 2nd gen axle. At full droop it'll rub the lower shock mount bolt causing possible damage.
