CV axle play at front diff junction
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dockoz, Jul 7, 2019.
  1. Jul 7, 2019 at 7:29 PM
    Darth ToyTaco
    Darth ToyTaco Well-Known Member
    New Mexico
    2010 Offroad Short
    Stuff
    Good luck! Hope it works.
    dockoz[QUOTED][OP] likes this.
  2. Jul 7, 2019 at 7:30 PM
    FishingPups
    FishingPups Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    Ok. Now we are getting somewhere. I had a wheel bearing on a Toyo Corolla that was going out and it felt like the noise and vibration was coming from the center of the car. Makes no sense right? Bet still it is a bearing.
    dockoz[OP] likes this.
  3. Jul 7, 2019 at 7:44 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Had to do it to my 4Runner at around 120K something.
  4. Jul 7, 2019 at 7:55 PM
    racerX969
    racerX969 Active Member
    Wow............:rasta:
  5. Jul 8, 2019 at 10:40 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    #2 is typically the LH (driver's) side front wheel bearing. They will not have play in them that you can feel until they are really bad. Sometimes they are going bad they have no play and still feel ok when you rotate the wheel- but when you pull the hub assembly you can feel that they're bad.
    There is a TSB on the LH output bearing on the front diff with the part numbers or you can use the ECGS bushing.
  6. Jul 9, 2019 at 8:14 PM
    dockoz
    dockoz [OP] Member
    Brian
    Omaha, Ne
    2010 Base Double Cab w/ leer cap
    Lightweight mod- broke and removed tailgate.
    PSA, don’t miss the wood block when massaging your rotors off.
  7. Jul 10, 2019 at 1:28 AM
    dockoz
    dockoz [OP] Member
    Brian
    Omaha, Ne
    I replaced the front left wheel bearing and all of the sound is gone. The wheel didn’t have excessive play and the bearing didn’t grind when I spun it.
    I’m still going to check the CV axles again this weekend and i’ll Get back to y’all.
    As of now, I’m tentatively saying it’s fixed and it was a bad wheel bearing.
    Thanks for all of your input.
  8. Jul 10, 2019 at 5:05 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    I could have sworn i had the shaft play where it meets the diff since pretty much new, so i havent looked at it again in 4 years.
  9. Jul 10, 2019 at 6:27 AM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Order the ECGS bushing and do that as well. You will remove all the slop on the CV axle bell and save future problems too. Put a word out to borrow a removal tool for the needle bearing as well.
    It's good to see a plan come together.
  10. Jul 10, 2019 at 6:40 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I feel like the CV shouldnt have a 1/4" play at the diff though.. Regardless of the wheel bearing. But I guess thats something you'd never see normally
    whatstcp likes this.
  11. Jul 10, 2019 at 6:44 AM
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    PSA, next time use the threaded hole (just to the right of your circle) and use a bolt to push off the rotor! :yes:
    Darth ToyTaco and SR-71A like this.
  12. Jul 10, 2019 at 7:32 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    M8x1.25 to be exact :thumbsup:
    (Used this when replacing my brakes last week. One hit with the impact and they popped right off)
    llamasmurf and seedy_tea[QUOTED] like this.
