CV axle popped out.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Indyteecee, May 3, 2019.
  1. May 3, 2019 at 10:15 PM
    Indyteecee
    Indyteecee [OP] bad at building Toyotas, good at breaking stuff
    Wyatt
    Utah
    04 Tacoma Double Cab TRD
    Sure, but if I’m still having problems with CV axles, it’s not limiting it enough.
  2. May 3, 2019 at 10:18 PM
    Indyteecee
    Wyatt
    Utah
    Very possible. When I have time I’ll take everything back apart and see what’s up.
    landphil[QUOTED] likes this.
  3. May 3, 2019 at 10:19 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    I always just spit on it and put it back in.
    Indyteecee[OP] likes this.
  4. May 3, 2019 at 10:23 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    If you're running a sway bar... too much down travel wasn't what caused your problem.
    I'd bet it was your CV wasn't snapped in all the way (as mentioned before)
  5. May 3, 2019 at 10:32 PM
    Indyteecee
    Wyatt
    Utah
    Yes. I will pop it back in and then if it pops back out again, I’ll go from there.
    landphil likes this.
  6. May 4, 2019 at 11:48 AM
    Indyteecee
    Wyatt
    Utah
    Bumping my own thread.
    Does anyone have any recommendations for some aftermarket CV boots that can handle more extreme angles?
  7. May 4, 2019 at 1:39 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    SDHQ and RCV (I think) make high angle boots but I've heard mixed reviews on them.
    Another option while you have the axle out is to do the boot slide mod, slide the boot down 3/4 an inch to space out the fins more so that they don't rub. Only problem is that then the clamp isn't sitting in the groove that it was designed to sit in so you have to make sure you clamp it real good.
