Cv axle popping out of hub
Discussion in '1st Gen. Tacomas (1995-2004)' started by Quicktrickle, Dec 4, 2015.
  1. Dec 4, 2015 at 5:38 PM
    Quicktrickle
    Quicktrickle [OP] Member
    2000 Toyota Tacoma 4x4 ext cab
    Hey guys I have 2000 Tacoma 4x4 ext cab. I've recently replaced the front passenger side wheel bearing and cv axle. Since I've had the cv axle pop out of the hub 3 times. The snap ring on the shaft will still be in the groove and the axle won't pull out of the hub but pops out enough the axle flops in the hub. All 3 times it stayed tight attached inside the tranny. I've scratch my head over this for awhile now. Anyone ever had any dealings with this occurring? Maybe the bearing inside the hub wasn't seated properly? Any input would be greatly appreciated
  2. Dec 4, 2015 at 5:41 PM
    Lost pilot
    Lost pilot Well-Known Member
    Reid
    Nashville, TN
    04 TRD 4x4
    Front window tint, some other stuff
    That's wierd.. Is it the right size axle? I've replaced mine and there's pretty much no way it would ever pop out from what I can tell.
  3. Dec 4, 2015 at 5:42 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Isn't there an axle nut attaching the axle to the hub? Or am I not reading this right?
    RelentlessFab likes this.
  4. Dec 4, 2015 at 5:47 PM
    Quicktrickle
    Yeah same size that I took out. It doesn't make sense to me. I could understand the other side coming out if it wasn't all the way in. Last time I changed the inner seal and it stayed tight inside the hub about 2 weeks and now it has done it again. There's about an inch between the inner seal and the outter cv joint housing. The axle just flops inside the hub
  5. Dec 4, 2015 at 5:49 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    are you manual hub or ADD front?
  6. Dec 4, 2015 at 5:49 PM
    Quicktrickle
    It didn't have one when I took it apart. It has manual locking hubs. From everything I have seen the Manual locking hubs doesn't have the axle nut but I could be wrong?
  7. Dec 4, 2015 at 6:05 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    @BDN don't you have manual hubs?
  8. Dec 4, 2015 at 6:08 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Yes. There is a bolt and washer right in the center of the shaft, and a circlip that holds the shaft in place.
  9. Dec 4, 2015 at 6:09 PM
    Quicktrickle
    Yeah it has the bolt and washer in the center and the circlip in the groove on the axle. It doesn't make sense to me how it's pulling out enough the cv will flop inside the hub
  10. Dec 4, 2015 at 6:14 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Like this?
  11. Dec 4, 2015 at 6:17 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    subd for outcum
  12. Dec 4, 2015 at 6:17 PM
    Quicktrickle
    Yep exactly like that! The circlip will still be in the groove and the axle won't pull completely out of the hub but it pulls out enough to just flop it around inside the hub
  13. Dec 4, 2015 at 6:20 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    and, stupid question, you have that slotted/grooved washer behind the circlip too?
  14. Dec 4, 2015 at 6:23 PM
    Quicktrickle
    Yeah. I've actually taken the drive side apart to make sure i didn't lose something and leave something out. I've gotten very good at getting cone washers out lol
  15. Dec 4, 2015 at 6:25 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I don't know man. Maybe some pics would help us?
    That washer and circlip is what holds the shaft in place.
    Do you have a brass bushing behind that washer?
  16. Dec 4, 2015 at 6:30 PM
    Quicktrickle
    Okay I haven't torn it apart again yet. It's on the agenda tomorrow, I'm losing time in the woods hunting. Yeah I have that brass bushing. It didn't have the brass bushing that goes on the inside where the cv starts in the hub. I may not be wording that correctly
  17. Dec 4, 2015 at 6:33 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  18. Dec 4, 2015 at 6:33 PM
    Quicktrickle
  19. Dec 4, 2015 at 6:37 PM
    Quicktrickle
    I could see a little play but there's about an inch between the inner seal and the outter cv joint housing
  20. Dec 4, 2015 at 6:40 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    An inch gap? Are you sure it's the right CV assembly for your truck?
    I wonder if you maybe got one for a Tundra.
    That just doesn't sound right. Might have to pull the other side just to measure for length and be sure.
