CV axle removal strap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Aug 7, 2019.
  1. Aug 7, 2019 at 8:15 AM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Somebody makes a tool that's basically a knotted rope you loop around your CV axle, then use a mallet as a slide hammer to pop your axles out in the field, without having to climb under the truck when you're in a sketchy situation. Does anyone know who makes it? I saw it on IG or something a few months ago.
  2. Aug 7, 2019 at 8:18 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    https://www.gziladesigns.com/products/cv-removal-tool
    I just bought one of these and used it on Saturday. Still takes some effort but it's much more effective than the pry bar method. Some will laugh at the price, but I'm not disappointed after pulling 2 CVs with it.
  3. Aug 7, 2019 at 8:20 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
  4. Aug 7, 2019 at 8:21 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Hmm thats pretty neat. Honestly $30 isnt too bad, but could probably make do with some heavier rope if you had any on the trail
    BassAckwards likes this.
  5. Aug 7, 2019 at 8:29 AM
    desertjunkie760
    Shane
    Check My Sig.
    It's definitely something you could make on the trail if you were good at knots. The rope has to be pretty strong though due to the amount of force you have to apply. It also has to be pretty small rope to fit on the inside of the flange.
  6. Aug 7, 2019 at 8:56 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The key with getting a CV out is placement of the C clip on the CV spline shaft inside the spider gear. You want the opening of the C clip that gets compressed as it goes through the spider gear at the bottom. If the CV doesnt wanna come out easily, push the CV in to allow it to move freely, spin the shaft 1/6th of a turn, give the cup a few taps to settle the C clip and try again. You will find the CV comes out almost too easy when you get the C clip in the right position.
    6 gearT444E and zippsub9 like this.
  7. Aug 7, 2019 at 11:40 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Thanks! That's not the one I was looking for, but same concept.
  8. Aug 7, 2019 at 1:09 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Honestly, I've had pretty good luck with the pry bar. Key is knowing where to pry and doing it in a quick and abrupt motion. You want a quick POP of the bar, not a slow loading of force. This uses inertia to quickly compress the c-clip and slide the axle out.
    PS: for those of you doing this on the trail it is a good idea to carry a quart of gear oil or jack up the truck fairly high on that side so the oil doesn't spill out.
  9. Aug 7, 2019 at 1:10 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Pry bar has never worked for me.
    I made a similar tool and it works in seconds
    SR-71A likes this.
  10. Aug 7, 2019 at 1:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Pry bar doesn't work with an IFS skid on, but gives more control and less chance of damaging the seal, but on the trail that's not a huge priority.
    I would just buy this 10' kevlar rope, since kevlar has almost zero stretch. Then just tie both ends in a loop, and make a lasso. One end over CV, other end slip a 3lb hammer in and wala.
    https://www.amazon.com/Spearit-30FT...pe&qid=1565209098&s=gateway&sr=8-3&th=1&psc=1
    Then give one to a buddy since you'll have leftover rope.
    Actually I'm going to do that now......
    Atlas86 and SR-71A like this.
  11. Aug 7, 2019 at 1:33 PM
    desertjunkie760
    Shane
    Check My Sig.
    Pry bar doesn’t work with skids. At least in my experience. A pry bar also takes up a significant amount more space and weighs more than rope.
  12. Aug 7, 2019 at 1:34 PM
    desertjunkie760
    Shane
    Check My Sig.
    That’s a good option, but it requires friends...
    I don’t have any of those. :rain:
    SR-71A and EatSleepTacos[QUOTED] like this.
  13. Aug 7, 2019 at 2:30 PM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    Pry bar method requires getting under the truck, not always safe if you're on a trail with no good jackstand placement. The strap enables removal from the side. If I was planning another CV replacement I'd get the $29 one just to avoid all the profanity I use during prying.
    Whoever posted about prying in one spot, then pushing the axle in and rotating a bit before prying again was on the money. Picking one random spot and fighting with it is wasted time, unless you somehow hit the magic C-clip placement on the first try.
