CV axle replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by BossFan, Jan 15, 2023.
  1. Jan 22, 2023 at 7:03 PM
    #61
    eon_blue
    Azusa, CA
    I had zero issues removing mine in a few minutes...but I also removed it knowing I wasn't going to reinstall it which may have factored into things
    Kwikvette[QUOTED] likes this.
  2. Jan 22, 2023 at 7:03 PM
    #62
    BossFan
    BossFan [OP] Well-Known Member
    Frank
    NJ
    03 TRD 4x4 X-Cab MT swap
    Tundra brakes Bilstein 5100s OME springs
    Thanks kwikvette!
  3. Jan 22, 2023 at 7:07 PM
    #63
    BossFan
    Frank
    NJ
    I know it was suggested that I don't need new UCAs because I don't really do any hardcore wheeling, but my OEM UCAs are pretty rusty. All the paint is long gone. I do keep them spayed with Flui Film, but was wondering if I should remove them, clean/blast them, and respray them. Maybe we something like POR-15 of duraliner. Or something that's pretty durable. I could probably get them powder coated, but then I may as well just buy new aftermarket UCAs. Thoughts? As soon as I feel better, I will take some photos of their current condition.
    jerrybear likes this.
  4. Jan 22, 2023 at 7:21 PM
    #64
    GrungeEXP
    GrungeEXP Active Member
    ‘01 Gold Tacoma 2.7L
    mine required vise grips + impact gun since the Allen socket was very worn. Else I’d probably have reused them.
  5. Jan 22, 2023 at 7:51 PM
    #65
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yep
    I didn't do anything to ruin being able to reinstall them either; just an impact wrench is all it took.
    Says something when you can easily swap LBJs within minutes too :anonymous::bananadead:
    eon_blue[QUOTED] likes this.
  6. Jan 23, 2023 at 11:40 AM
    #66
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    earlier it was posted not to worry about uca’s if you dont offroad the truck much and I agree with that. I would only add that if you are in there already, mechanically inclined (which you are) and have the money, throw em on. it wont hurt and may actually cause you to go out and wheel more lol. A big plus in my book. you dont have to be a “hardcore” wheeler to reap the benifits of uca’s offroad imho.
  7. Jan 25, 2023 at 7:22 PM
    #67
    BossFan
    Frank
    NJ
    Thanks Jerry. If I did add UCAs to the list, what brand would you recommend for a non-hardcore wheeler like me.
    jerrybear[QUOTED] likes this.
  8. Jan 25, 2023 at 7:43 PM
    #68
    Kwikvette
    Fresno County
    4 run, 2 don't
    Even if you wheel, you can still get far on stockers.
    They don't inhibit travel as much as one would think, but one could benefit greatly with the added caster for getting proper alignment when lifted (if you can't achieve alignment).
    Your CV axles will limit you before your UCA's do.
  9. Jan 25, 2023 at 7:51 PM
    #69
    jerrybear
    17 off-road
  10. Jan 25, 2023 at 8:07 PM
    #70
    jerrybear
    17 off-road
  11. Jan 26, 2023 at 8:27 AM
    #71
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    The advice to not upgrade the UCAs (if you don't wheel, etc) is more based around what most after market UCAs do with the suspension geometry. They all alter the location of the ball joint which affects the alignment. They are also just costly (maybe not the SPC/Mevotech) so if they aren't necessary to correct alignment issues, most here (correctly) don't recommend them.
    If you need to replace your UCAs because of rust or damage, by all means, go for it. But also consider an aftermarket OEM replacement, Moog, etc.. Don't go for a $2000 Uniball UCA you don't need :thumbsup:
    BossFan[OP] likes this.
  12. Jan 31, 2023 at 3:48 PM
    #72
    jerrybear
    17 off-road
    yeah. I wouldnt spend 2 grand on uca's either
  13. Feb 1, 2023 at 3:57 AM
    #73
    BossFan
    Frank
    NJ
    Thanks everyone. All the parts came in from McGeorge Toyota so am going to work on it this weekend.
    I have been installing an ARB bumper the last couple of nights, and have that trail-fires, but will wait until after I do LBJ and CV stuff since having that off definitely provides more room/light to work.
    https://www.tacomaworld.com/threads/front-bumper-question.787852/page-3
  14. Feb 1, 2023 at 5:45 AM
    #74
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nice, just remember your torque values.
    CVs and LBJs go hand in hand so it'll be a really quick job.
  15. Feb 10, 2023 at 6:04 AM
    #75
    BossFan
    Frank
    NJ
    I’m going to tackle this job this weekend, but have a new question. I commented earlier in the post that my truck pulls to the right. Someone said that probably had nothing to do with the CV axle, so I figured once I did this work (axle, LBJ) I would have it aligned. I even bought a KPOffeoad alignment kit. But the other thing I noticed is that my steering feels stiff. I checked the p/s and the fluid level seems ok. I even used a turkey baster to remove the old stuff and put in new. I guess my question is: what are the signs that a rack and pinion is going bad? Mine is rusted really badly, but that shouldn’t make it now wirk, right? I’ll post a picture of it later when I put truck on lift.
