CV Axle Seal ECGS Bushing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCExplorer, May 25, 2020.
  1. May 25, 2020 at 11:23 AM
    BCExplorer
    BCExplorer [OP] New Member
    2017 Blue Tacoma TRD Sport
    Hi Everyone,
    I'm new to the forums and am going to be doing the ECGS Clamshell bushing on my truck this weekend as I unfortunately got the vibrations after lifting it. My truck has fairly low mileage at 80,000km or 49,000 miles and my question is, should I change out the CV axle seal along with doing the bushing? I've not had any problems with the seal at all and I'm hesitant to do it as it seems to be a difficult task to set it to the right depth as if its not it will leak and be a pain to deal with. Did most people change the seal out at the same time, or did they just call it a day with doing the bushing and leaving the factory seal?
    Thanks
    PS. Hopefully my terminology is correct and hopefully you can make out what I'm trying to get at.
  2. May 25, 2020 at 11:27 AM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Leave the seal it will be fine
    whatstcp likes this.
  3. May 25, 2020 at 11:28 AM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    I did mine at 17k miles and I changed out the seal. Did I need to? Probably not. Cheap insurance.....yep.
  4. May 26, 2020 at 8:14 PM
    RNO_TACO
    RNO_TACO Well-Known Member
    Brent
    Roseville, CA
    2019 Cement Grey Tacoma TRD Off-road 4x4 DCSB
    A.R.E. Topper with victory topper rack, blacked out exterior emblems, star armor side steps, TRD CAI, TRD Pro exhaust, Method MR305 NV 16in Rims, TRD PRO front grill, Meso coin holder, TRD Pro skid plate, Kings 2.5 coilovers with remote resis front and rear, OME HD Dakar’s, ECGS, LT285/75R16 KM3s, Dirt king UCAs, Meso gas cap holder, Meso blacked out interior kit, TRD start/stop red button, AVS low profile window guards, AVS low profile hood protector, Full LED upgrades inside and outside, decked bed storage system. And I’m sure there’s more I’m missing lol
    I recently changed my needle bearing with EGGS out as well with only 10k on the clock. I ordered the seal as well. As others have said about the seal, do you “need” it replaced probably not but it’s nice to have it all done while you have it tore apart. Plus, you’d be upset if you messed up the original seal during disassembly/reassemble and didn’t have one on hand to replace it. Just my 2 cents anyway. Good luck with the install. I actually had fun with mine minus get that damn cv axle out. Pretty straightforward install with the right tools. Take care.
  5. May 26, 2020 at 11:30 PM
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    Have a spare seal on hand just in case....they aren't but about $15.
    I changed my bearing out with the ECGS bushing with about 3k miles on the truck as I recall. I did not replace the seal, but made damn sure the shaft did not drag across the seal on the way out, or on the way back in. Now with 22k miles, no leaks.
    If I was doing it with 50k miles on the truck, I'd personally replace the seal. But as long as you're careful not to damage the seal, it's going to be fine. Supporting the shaft as you take it out and put it back in so it doesn't rub or pinch the seal is key. But if you don't have experience changing CV's, you likely run higher odds of an "oops". Best have a spare with you, lest you need it, don't have it, and waste half a day running around trying to get one.
    I've done probably a half dozen of these (replacing CV axles), and the one time I did get a leak, I was surprised at the minimal amount of contact and pinch it took to ruin the seal and cause a leak. Super careful taking it out, and you drag across or pinch the seal, replace it.
    Beware that use of the bearing puller and possibility of pinching the seal with that as well.
  6. May 27, 2020 at 12:33 AM
    Carrot Top
    Carrot Top Well-Known Member
    Mark
    Las Vegas, NV
    2016 Inferno Tacoma TRD 4x4
    I installed my ecgs bushing at 30,000 miles. I did buy a replacement seal but decided not to use it since the original seal looked in great shape. I was very careful not to damage the original seal when pulling the original bearing. I went with the idea that original did not leak so I did not replace it. I have no leaks. However if you damage it then you must replace it.
  7. May 27, 2020 at 4:37 AM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Just replaced my needle bearing with the ECGS bushing last night. My truck only has 14,000 miles on it, but I went ahead and replaced the seal as well while I had it all apart. No leaks and the vibration from my recent lift is gone.
  8. May 27, 2020 at 4:45 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I did the same bought the seal just in case I nicked it during the bushing install. It was cheap insurance.
    Lt. Dangle likes this.
  9. May 27, 2020 at 7:16 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I replaced my bushing at 30k miles and bought the seal as well. I ended up not replacing the seal and will probably never have to. As long as I keep the seal in a drawer in my toolbox, the law of averages should protect me.
    The second I get rid of it, though...
    danielgonzzz, whatstcp and mnmsddy like this.
  10. May 27, 2020 at 7:22 AM
    mnmsddy
    mnmsddy Well-Known Member
    portland, or suburbs
    2018 White Tacoma TRD Offroad
    I cannot count how many times I have needed something I had stored for years, right after I threw it away.
  11. May 27, 2020 at 7:26 AM
    Lt. Dangle
    Ohio
    Yep. I think it's borderline hoarding, but I look at as self insurance. It's like a Mayan sacrifice to the goods, only in goods form.
  12. May 27, 2020 at 7:33 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I replaced my oil seal when I did mine at 15K. I didn't want to take the chance of it leaking after I replaced the bushing. You shouldn't have any issue setting the seal if you have the right tools. You can pick up a bearing race/seal driver at HF for the price of a second seal.
  13. Jun 15, 2020 at 5:44 PM
    Flyin200ln
    Flyin200ln Member
    2012 DCLB
    Just installed the ecgs bushing and replaced the seal. Must have installed the seal wrong now it leaks. Any suggestions on setting the seal as far as how deep, 5.5 mm?
  14. Jun 15, 2020 at 8:14 PM
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    The seal should be flush, I barely got my seal installed and I let the CV push into where it wanted it. No leaks the second time around.
    Skip to 9:30 for the seal installation
    https://youtu.be/WJ4_7G12Esw
    Flyin200ln likes this.
  15. Jun 16, 2020 at 4:20 AM
    rookhoe
    rookhoe Well-Known Member
    Finger Lakes, NY
    2016 MGM Tacoma TRD Offroad
    I had ordered the seal in the event that I would have to install it. If you don’t need it, now you have a spare one.
  16. Jun 17, 2020 at 9:32 PM
    Flyin200ln
    Flyin200ln Member
    2012 DCLB
    Thanks for the tip,worked perfect!
