cv axle seal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chaseb, May 26, 2012.
  1. May 26, 2012 at 8:20 PM
    Chaseb
    Chaseb [OP] Member
    Florida
    04 tacoma sr5
    3 inch body lift, flowmaster exhast, 33inch daytom a/t, blacked out windows, 2 12inch kicker subs
    i am replaceing my cv axles this weekend and someone told me that i should replace the front axle seal beetween the cv and diff. while im in there....all i can find are seals called wheel seals.....are these the same thing? also how do you change them?
  2. May 27, 2012 at 9:14 AM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    when i had to do mine (they were leaking) i just went to the toyota garage and got them, and i'm not sure what they called them. to replace it's easy as hell. Once you have the cv out just use a pair of needle nose pliers and pull it out. to set the new back in, first rub some diff fluid around the rubber seal ( like you would when you change your oil on your oil filter), the just gently tap the new seal in. You may have to use a punch to get it all they way in but just be easy with it and you'll find that it's pretty simple.
  3. May 28, 2012 at 8:03 PM
    Chaseb
    Chaseb [OP] Member
    Florida
    04 tacoma sr5
    how far back should i tap the seal?
  4. May 28, 2012 at 8:36 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Measure the old one before you remove it!
  5. May 29, 2012 at 4:37 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    should be flush with the edge, make sure it's squarely tapped in
  6. May 29, 2012 at 6:08 PM
    mixaro
    maine
    exactly what he said
  7. May 30, 2012 at 7:55 AM
    Chaseb
    Chaseb [OP] Member
    Florida
    04 tacoma sr5
    thanks for the info.
  8. May 30, 2012 at 1:35 PM
    mixaro
    maine
    no problem thats what we're all here for
