Cv axle seals- should there be two of these?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sogoku19, Jul 23, 2021.
  1. Jul 23, 2021 at 5:37 PM
    Sogoku19
    Sogoku19 [OP] Well-Known Member
    03 Tacoma (black)
    Changed axles a while back did good around town for a month or two before I noticed a slight leak coming from the front diff. I assumed it was the seal that I opted to not change while I was in there and knew what I had to do.
    so I now have it out again and I noticed two “seals” that were stacked and I’m wondering if I didn’t have the old one off when installing my new axles. Pics to follow- should there be two of these? It/they belong between the cv and the diff.F7E3EF72-ABA1-4DB2-83D6-A6E5D5F2DD6E.jpg
  2. Jul 23, 2021 at 5:38 PM
    Sogoku19
    03 Tacoma (black)
    I’m case the photo doesn’t drive it home- both of these look identical as far as I can tell just one old and one new
  3. Jul 23, 2021 at 5:39 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Not usually.
  4. Jul 24, 2021 at 8:57 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Just to confirm, both of those were stacked into the opening on the front diff (drivers side) or axle tube (passenger side)?
    There is only supposed to be a single seal on each side. There isn't a stopping point, and the seals can be driven in further than spec if not done properly.. Are you the original owner of the truck? if not a previous owner or mechanic may have driven a second seal in.
    koditten likes this.
  5. Jul 24, 2021 at 11:10 AM
    Sogoku19
    03 Tacoma (black)
    That’s correct. Not the original owner. This is driver side. I didn’t noticed until they fell of the end of the axle before I could see which way they were facing( for reinstalling) so I cussed but then said “hey, wait a second.” Lol
  6. Jul 24, 2021 at 11:21 AM
    Sogoku19
    03 Tacoma (black)
    I re- read your post and I believe I understand more clearly- you’re exactly correct. I don’t think the were driven too far as they just fell off when I pulled the axle. I reckon this is the reason she was letting some oil out. This time I’m gonna go ahead and change the other seal that I suspected in the first place. I’m also putting on new rotors and pads and have new upper ball joints. I don’t have a press so I took the whole knuckle off and cleaned it up real good so I can take it up to a shop that has one.
  7. Jul 25, 2021 at 8:11 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I believe there is a Timmy video on replacing the seals- you should check that out before you replace them, as it contains instructions on setting the depth of the seals.
    You don't need a press to change out the upper ball joints. The right size puller should do the trick once the C-clip is removed. You can rent a kit from an auto parts store, or just buy the right one- they are useful to have.
  8. Jul 25, 2021 at 9:54 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    First, they are not seals. They are "shields" that get tapped on the inner joint, one per axle.
    They frequently get knocked off, overlooked and sometimes accidentally doubled up.
    Center left "dust cover"
    Here's one installed in real life from a file on another subject. It's a "New" (China) NAPA branded shaft.
    Toyota shaft.
  9. Jul 25, 2021 at 3:44 PM
    DeerHunter44
    DeerHunter44 Well-Known Member
    1999 3.4 4wd AT
    I swapped my driver side CV and was thoroughly confused for a while. The axle I pulled out didn’t have one of these shields but the new one had one pressed on out of the box. I inspected the outer seal area on the diff but there was no shield still in place. I have no idea what is going on but my best guess is one got left off during a previous swap? I went ahead and installed the new CV with the shield and so far no issues or leaking but I’ve only driven about 30 miles so far.
    Wish I could answer your question but I’m confused as well. Good luck.
  10. Jul 25, 2021 at 4:29 PM
    Sogoku19
    03 Tacoma (black)
    that’s the one and you showed which way they face. Thanks a tone, brother.
  11. Jul 25, 2021 at 4:30 PM
    Sogoku19
    03 Tacoma (black)
    so when I want to put the new ones in can I just torque it in like I did the lowers and tie rod ends?
  12. May 10, 2022 at 3:36 PM
    Tuluk
    Tuluk Well-Known Member
    1999 trd manual 4x4 ext cab
    Does anyone know where to source the CV axle dust sheilds?
    Mine got thrown away by a rebuilding shop and I can't seem to find the part number or identify exactly which part it is in the FSM.
  13. May 10, 2022 at 9:27 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    The FSM doesn't have part numbers.
    https://parts.toyota.com/a/Toyota_2...11_6721620/FRONT-DRIVE-SHAFT/674460-4302.html
    Here is the link for my truck. You should enter your vin... but the CVs should be same (provided you have ADD and not manual hubs).
    Tuluk[QUOTED] likes this.
  14. May 11, 2022 at 9:18 AM
    Tuluk
    Thank you friend, that is exactly the help I needed.
