cv axle separation question
Discussion in 'Technical Chat' started by woody6047, Mar 15, 2013.
  1. Mar 15, 2013 at 5:10 PM
    woody6047
    woody6047 [OP] McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    This seems like a really dumb question to me but im a little confused.
    While changing my axle seal on the front driver side i pulled out the axle and noticed that you can pull the shaft that goes to the hub and the sleeve that goes into the differential apart.... easily. I have only replaced four wheeler axles and they have clips inside to keep this from happening. So my question is should the axle come apart easily at the sleeve going into the differential? The only thing keeping it together was the CV boot.
    thanks in advance
  2. Mar 16, 2013 at 11:11 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    well dealership said they didn't know... haha
  3. Mar 16, 2013 at 11:12 AM
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    I just replaced my third last night with some friends.. I dont have a 4x4 but its a 2nd gen 2x4 and it slipped right out... very easily
  4. Mar 16, 2013 at 7:11 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    Yeah, if you remove the bands from the inner cv boot, you can essentially pull the shaft w/dog bones completely out of the tulip portion pretty easily while leaving the tulip inside the differential assembly. I leave the tulips in the differentials all the time when I replace the cv boots. I pull the rest of the half-shaft out of the hub after disconnecting the lower ball joint and then remove the remaining clips to dismantle the rest of the half-shaft. Then I change the boots, squirt in new grease, squirt some in the tulips as well, and then re-assemble.
  5. Mar 16, 2013 at 8:56 PM
    BamaToy1997
    Bill
    Navarre, FL
    Because of the amount of movement that you do have with a 4WD truck, many of them have gone to a "Free floating" CV joint. This allows greater movement and reduces binding at full suspension droop. Unless there is a suspension component that has failed, the joint will not slip out while the truck is assembled.
  6. Mar 17, 2013 at 1:28 PM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Thats great to know guys thanks a ton. All the other ones i had dealt with had clips to keep them together so when it came apart i was kind of confused. Already put back together and its good to go!
    Thanks again guys
