CV Axle snapped @ 8k miles
Discussion in '4th Gen. Tacomas (2024+)' started by BoBsworld21, Dec 3, 2024.
  1. Dec 4, 2024 at 10:01 AM
    #101
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
  2. Dec 4, 2024 at 10:01 AM
    #102
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    If we approach this from the legal angle, the manufacturer is not required to cover any failure due to any sort of modification you make, lifts, tires, wheels, or otherwise. They can deny a particular failure is a defect in workmanship because the failure was caused by a change you made, not by them building or installing something incorrectly. It's not a stretch of the imagination that a lift kit could cause an axle to fail prematurely. Thing is, the dealer should have said that; "it's normal wear and tear" is a bullshit reason. That implies that it's normal for an axle to fail in 8k in general. It's not. Full stop.
    The manufacturer actually is required to prove that your failure was caused by a modification or abuse or something to deny coverage. They could blame any modification you made on any failure you had otherwise, like installing a seat cover causing a wheel bearing to fail or something equally nutty. It's why I'm eagerly awaiting the inevitable suit about GR Corolla owners having warranty coverage denied and being told it's because they exceeded 80mph. Toyota's lawyers will have to make some pretty wild claims to support that nonsense. But I digress.
    The not so fun part with this is that the actual remedy for denied coverage under a warranty — after exhausting normal avenues like getting second opinions and yelling at various people until you decide you're not getting what you want — is to sue whoever denied your coverage. You've gotta go to court and convince a judge to order them to cover your repair. Even if you're entirely in the right, this is a pain in the ass. In this case, OP's likely not entirely in the right. Even worse, the monetary cost is likely larger than what can be brought in a small claims kind of setting, so the quicker and cheaper (and often not requiring an attorney) avenue isn't available. They'll have to file a proper civil suit, pay an attorney and court costs, and then find out that their lift kit was — based on a preponderance of evidence — the cause of their axle failure and the cracked housing. They still have to shell out to pay for the repair and now have a legal bill and wasted time to contend with.
    Full disclosure: IANAL, but I feel pretty confident in explaining how this works having read quite a bit about it.
    Phlogiston likes this.
  3. Dec 4, 2024 at 10:03 AM
    #103
    SHADOWDRIFTER19
    SHADOWDRIFTER19 Well-Known Member
    RH
    2019 2.7L TSS OR
  4. Dec 4, 2024 at 10:06 AM
    #104
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR iForce Max
    Issues that have not been discussed already?
    I finished my dinner. Where is my pudding?!
  5. Dec 4, 2024 at 10:08 AM
    #105
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    JB_TN likes this.
  6. Dec 4, 2024 at 10:10 AM
    #106
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Same. Both times for me near full lock against an obstacle. You think I’d learn.
  7. Dec 4, 2024 at 10:13 AM
    #107
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    LOL OOOF. backed out into 4wd and as soon as that front right tire hit pavement bind n pop. That CV was at FULLL extension it didnt break it popped out of the cup.... cant say I have ever seen that on a 2nd or 3rd gen with stock uppers and lowers even at literal full over extension droop with a broken shock do this..... another toyota failure in design as they fair well know these trucks are going to be lifted.
    Durango95, TnShooter, henryp and 3 others like this.
  8. Dec 4, 2024 at 10:16 AM
    #108
    SchwarzeEwigkt
    Central NY
    Out of curiosity, why do you think it's Toyota's responsibility to account for aftermarket modifications?
  9. Dec 4, 2024 at 10:29 AM
    #109
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Looks like this has nothing to do with stress/breaking an axle and more so to do with the axle being too short causing the tripod joint to pull out of the cup. Cycle your suspension folks
    Durango95 likes this.
  10. Dec 4, 2024 at 10:30 AM
    #110
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Pro
    funny. There is a tube influencer video from this past spring, 24 tacoma (I think it was sport) vs a Zr2 on an icy mountain trail …the tocama was struggling with grip (stock tires) on easy terrain and sure enough it popped the cv axel
    Durango95 and Dirty Harry like this.
  11. Dec 4, 2024 at 10:30 AM
    #111
    dleithaus
    Washington State
    TRD Celica!
    I had two Celicas in my life. 1978 (GT) and 1987.
    I loved the 2004 GTS, but by then was onto trucks. Still see them occasionally. No stickers.
    I guess someone wanted to rebadge it with the TRD sticker on the rear quarter panel?
  12. Dec 4, 2024 at 10:33 AM
    #112
    Jacob06
    Jacob06 Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    Crank case= engine block, yes?
    For what its worth, I think at $5k, replacement of all parts and labor, that Toyota is probably still eating a lot of this, just not all of it.
    I cant imagine what the cost of an engine block swap on this truck would be, but $5k sounds a bit light. Probably cheaper than the wheels tires and lift...
    Still sucks, but I think it would be a lot worse out of warranty.
    What all exactly are they proposing for the $5k? Maybe see about getting some TRDOR CV's or those Imaginary TRD Lift CV's
    In fact, maybe you could implore them to do a little more since Toyota spent all of 2023 & 24 saying there would be a factory lift available along with all of these other parts that still aren't available.
    You probably wouldve bought the damn Red or Silver Cv's if you had the option like they advertised
    I don't see this as being ALL your fault, you probably bought all of what you thought was the best stuff available for what is advertised as the best truck for this purpose.
    Last time I checked Icon wasnt in the CV business, so where the hell else are you supposed to get longer, stronger CV's for a truck who's 700 page manual mentions nothing of lifting the truck 2.5" or more and not being able to use reverse?
    Did Toyota let you know that you would be their PSA administrator on lifting too high when they took your $50k?
    I know this is all very unsatisfactory to you, but you should try to play ball with them.
    PUMPKINKING likes this.
  13. Dec 4, 2024 at 11:01 AM
    #113
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    $60 dollar bushing vs 5k for a new diff?
    kimosabe15 likes this.
  14. Dec 4, 2024 at 11:01 AM
    #114
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If you are referring to the TFL video, that was an OR, and the CV axle didn't pop. The ADD sleeve in the front diff sheared. Toyota's solution was to adjust the ECM software to limit torque more conservatively when A-Trac is active. Even though the front diffs are similar, 3rd gen never made enough torque for the same failure mode to happen...
  15. Dec 4, 2024 at 11:11 AM
    #115
    Jacob06
    Atlanta
    2024 TRDOR 6MT
    I think Tacomaworld should start a class action lawsuit because Toyota still hasnt released their damn TRD lift kit yet.
    I was supposed to be able to add all these parts to the truck at the time of purchase and have them warrantied.
    Here we are 1 year in, and you still cant order that ARB bumper, or the majority of the accessories they are advertising.
    When my truck was purchased in May, you couldnt even get a damn skid plate for it
    Has a lawyer not bought one of these trucks yet!?
    PUMPKINKING and SH10151 like this.
  16. Dec 4, 2024 at 11:21 AM
    #116
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Who told you that?
  17. Dec 4, 2024 at 11:22 AM
    #117
    Sagebrush
    Gens 1, 2, 3, and 4
    Because I have a 2024, not to troll.
  18. Dec 4, 2024 at 11:23 AM
    #118
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    And you could argue in a court of law that you replaced tires with the same factory specified sized tires as indicated in the owners manual, maintenance manual, and door card on the vehicle. You're making a dumb argument to try and prove a point thats just simply wrong. Manufacturers don't deny warranty claims for components (including stock size tires as indicated in the owners manual, maintenance manuals, and door cards). The point still stands - they can (and often do) deny warranty claims for modifications that alter the vehicle from its stock configuration (including oversized tires).
  19. Dec 4, 2024 at 11:24 AM
    #119
    FunknNasty
    San Jose
    2022 Pro
    yeah, I think that was the clip, thanks. I do remember (now) they got it to the dealer where Toyota had an engineer look at it and diagnosed what you shared.
  20. Dec 4, 2024 at 11:26 AM
    #120
    Jacob06
    Atlanta
    2024 TRDOR 6MT
    Go to Toyota.com and read up on their TRD spam.
    If Toyota did what they advertised this OP wouldnt be here right now
    I'm pretty sure theres video of Sheldon Brown saying you could get all of this imaginary stuff in one of their press videos
